Your Tappan dealer can help you with this. You have a good named unit so it shouldn't be a problem. You could also check with your gas company as to where to get the conversion parts.
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting back to natural gas from LP) This range leaves the factory set for use with natural gas. If you want to convert to LP gas, the conversion must be performed by a qualified LP gas installer. The conversion instructions and LP orifices can be found attached to the range next to the pressure regulator. Keep these instructions and the orifices in case you want to convert back to natural gas.
Just change the orifices. Also adjust the pressure control regulator by reversing the built in plastic spacer, the regulator supplied is a dual fuel type. Any work should only be carried out by a person who is qualified to do so for safety reasons. Dacor are very unhelpful when I posed the same question directly to one of their technical advisors. The poor level of this persons 'technical' knowledge both surprised and concerned me.
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
hi thanks for the question the brass fitting at the burner unscrews to change from natural gas to lp if its screwed in all the way back that off till you get a nice blue flame do it to all burners thanks the appliance doc
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
