Question about Magic Chef CGR3742 Gas Kitchen Range
I have the reverse problem
My gas stove is set for natural gas, I need to find the converters to change the Tappan Range to Liquid Propane
  • Anonymous Mar 12, 2014
    change from natural gas to propane
Try your termostat
Posted on Feb 06, 2009
How do I know if my Caloric Heritage gas range is propane or natural gas? It is a used stove that was given to us
Stoves are usually sent from the factory set for natural gas. they have to be converted to Propane. If it is set for propane the flame will be very low on natural gas. If set for natural gas on propane the flame will be very large. The orifices for natural gas are much larger than propane orifices. and the regulator is converted acordingly.
Nov 10, 2014 | Kitchen Ranges
Convert propane to natural gas on tappan TGF657 range
go to hardware buy a valve for that type fuel and change them out
Feb 04, 2012 | Tappan TGF657 Gas Kitchen Range
Need to go from natural gas to Liquid Propane. What is the wright way to do this.I have a GE Spectra stove. #JGBP35WEA3WW
You need to have the orifices changed on the stove to LP and the regulator on the oven converted, This should really be done by a professional, if it is not done correctly you can cause damage to your appliance and home. http://www.sensus.com/gas/pdf/Orifice_Change_Out_Procedure.pdf Hope this Helps Ryan
May 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
I just converted a Tappan stove to lp and cant get to light. It acts like no propane is getting to the burners and pilots.
HI, Things to check. Did you reverse the cap on the regulator? Adjust the oven orfice by turning it clockwise until it reached the bottom of the threads? Some mofels have a small shut off on the gas valve as well.
Change the burner orfices?
Make sure the gas shut off valve is turned on all the way?
Just a check list. I hope this helps you.
Vic
Jun 06, 2009 | Tappan MGF500PBW Gas Kitchen Range
Natural gas to LP converters
Your Tappan dealer can help you with this. You have a good named unit so it shouldn't be a problem. You could also check with your gas company as to where to get the conversion parts.
Feb 05, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan Range Model TGF351ESJ Nat. Gas to Propane
Yes you can convert the range
2. Provide an adequate gas supply.
This unit is pre-set to operate on 4" natural gas manifold
pressure. Aconvertible pressure regulator is connected to the
manifold and MUST be connected inseries with the gas supply
line. If the LP/Propane conversion kit has been used, follow
instructions provided with the kit for converting the pressure
regulator to LP/Propane use. The LP kit can be found on the
back side of the range (some models).
I yours does not have the kit on back go to sears to get one.
Good Luck
Please rate FixYa!
Dec 19, 2008 | Jenn-Air JGR8855BDS Gas Kitchen Range
CONVERTING TO PROPANE FROM NATRURAL GAS
just need to change out orifices in gas line natural gas company should have new ones in stock
Aug 23, 2008 | Tappan TGFS_63 Gas Kitchen Range
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Change from lp to propane on my whirlpool stove
Propane is LP...(i.e. Liquid Petroleum)
The burners are working only as a fluke. It is extremely dangerous to operate a natural gas stove on propane. STOP USING IT IMMEDIATELY. Call your local propane supplier and ask them about converting it to LP/Propane.
Jan 15, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Magic Chef CGR3742 Gas Kitchen Range Logo
110 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
