Back to:
Tags:
RCA D6520
Multiswitch and Old RCA Receiver
By Gary10 - usenet poster
I just purchase a DirecTv Tivo Sony Sat T60. Before I install it I put in a
RCA Powered MultiSwitch and tested it with my 2 current receivers. The Newer
one, an RCA DirecTv Plus system. It works with no problem. I am getting a
signal strength of over 90 on both odd and even transponders. I also have a
old RCA receiver.
This one only gets signal from the odd transponders. Taking the multiswitch
out of the picture and putting in a connector the old receiver gets a signal
strength of around 90 on both odd and even transponders.
What could be the problem or can't the old receiver drive the multiswitch
Posted via Newsfeeds.Com, Uncensored Usenet News
# - The #1 Newsgroup Service in the World!
Over 80,000 Newsgroups - 16 Different Servers!
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Luisa_K
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Also a bad LNB output can cause this. I think that or one of the ports will
be the most likely suspect.
T
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Multiswitch and Old RCA Receiver:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Pasty
Rating: 0%, 0 votes
My 1st gen RCA DRD102 box works just fine with with my D6520 unpowered
multiswitch. I have, however, found that one of the ports is bad (low
signal) and another port has a flaky relay.
-Joe
Thank You!
Solution #3
Not Rated (0)
pandamama
Rating: 0%, 0 votes
If memory serves, the "DirectTV Plus" models differed in being capable
of tuning between two satellites but older models could only look at
one. It's a basic requirement that all DirectTV receivers be able to
tune even/odd transponders and yours appears to do so when the
multi-switch is not in the loop.
Sounds like something else is amiss in your setup. Weak DC voltage
caused by poor cable or connection? Marginal multiswitch?
If all else fails, look at the DC voltage output on your cable-in
port(s). If they are OK, make similar measurements at the
multiswitch.
Thank You!
Can you Help with these Networking Hubs and Switches problems?
Attansic L2 Fast Ethernet Adapter je ne peut pas trouver...
which port may i use for GS8100 Router configuration with...
I'm using an 8 port hub and two laptops with MS Server...
Have a Dell PowerConnect 6248 layer 3 with 4 VLANs...
What is the host name or ip to acces Radware Link Poof,...
Loading problems.
Repair Service
Find Networking Hub and. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
