Question about GE Televison & Video
High pitched noise coming from set.
My Samsung HLM5065W has a high pitched noise eminating from the set. This is independant of any channel signal or external device connected to the set. It also appears worse when first turned on. Although I haven't opened the set up yet, I suspect it may be a filament rattle on the bulb but it seems extremely high pitched and rich in harmonics compared to filament rattle I have heard before. Could it possibly be a fan or maybe the little DLP chip with the mirrors on it, which I have no idea what it is called. I cannot tell the primary frequency of the noise but it is a guess at around 7-15khz and 80-85db so it is quite evident and annoying. Thanks I have the same problem coming from my GE-TV (model: 25GT536) that was passed down to me from my friend's parents. It comes and goes, this time it seems like it's staying indefinately. It's gotten so bad that I've been getting massive headaches. And, I tracked it back to only when I'm watching tv. So...this has to be it...right?
  • 57 Answers
Hi there high pitched noise form the set indicates that one of the coils inside the set are lose this happens with age and heat the coils are made of copper and are tightly glued or soldered together and can be as small as a bit of hair of as big as a pen tip the problem is that the coil is now vibrating which is causing the high pitch sound and sound be quite easy to identify with a good ear!
sometimes these can be sorted with a quick bit of solder to hold it in place on the main bord of where the coil is, but some times there is no cure due to very small braiding of the copper wire any attempt to solder may cause damage and breakage,
You may be able to replace the coil with another one from a good components store with the same value best thing is to take out the noisy coil and take it down to be replaced
the reason it appears worse when first turn one is that the coil is cold and vibrates alot more just like when the set is warm the coil expands like most metals do which stops it vibrating so much
i hope this helps a little good luck
Posted on Feb 05, 2009
  • 10,594 Answers
High pitch noise is coming from Color Wheel, installed in light engine next to lamp.
Color Wheel is available in Part Store and if you familiar with TV repair, can do it yourself or ask help of TV tech to fix it.
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High pitch sound from 50" projection TV monitor. It's not either fan unit, because that's what it sounds like. I have disconnected both fans and the noise is still there.
If its a hi pitch sound chances are its not recognizing the source or signal- try reconnecting cables and setting programs on the projection tv-
Keep us posted- thanks!
Jul 05, 2008 | Samsung Televison & Video
When The TV is running it makes a high pitched whinning that seems to be coming from the projector
its a bad color wheel and you may be able to replace it. You Tube has videos for this.
Look where the lamp faces and see if wheel missing segments or shattered.
Nov 27, 2012 | Samsung HLM5065W 50" Rear Projection...
Replaced the lamp in Samsung hl-s5086w and now T.V. won`t turn on but has a high pitch noise coming from back of set.
The high pitch noise is the color wheel that needs replace the noise is coming from a bad bushing that goes to the color wheel and is a common problem.
Dec 13, 2010 | Samsung HL-S5086W 50" HDTV
High pitch noise from the flyback
You can tell to some extent what it may be by listening carefully and trying to identify the location. If you, remove the back cover of the set; stay away from danger, just listen to where it seems like the sound is coming from. If it is coming from inside the high voltage cage it is the flyback. If coming from around the main power transformer it is one of the power supply parts.
Please Rate This Fixya solution
Jan 23, 2009 | Samsung HL-P6163W 61" TV
High pitched noise
I am about to post a in depth guide about how to fix this problem. It's because a capacitor inside the TV has blown which causes the buzzing high pitched noise. It's really easy to fix however and only costs about £1 / $2 to sort out.
You can read a similar guide here but I will shortly be uploading a guide on the buzzing problem!
Dec 22, 2008 | Polaroid FLM-3732 Television
High pitched rattling not associated with TV audio
Quite possibly the HVT arcing, which will eventually fail.
The problem with them arcing is they can be doing damage to other components.
Best to have it checked by an experienced tech.
Jan 06, 2008 | Toshiba 32AF42 32" TV
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
No my freind, without being there and looking around its a guess that the noise you hear is from the switching Power supply or SMPS(switch mode power supply. it could be an indication of something to come, as a breakdown as maybe the power supply is being a little bit overloaded for some reason, or could just be a loose transformer or coil winding. Not alot to do with it unnless you locate the source. i would contact Samsung and see if there are any problems like this for this model. If they dont know then the best advice im sorry to say is live with it or call in a tech to check out the power supply or to locate the singing coil. Good Luck PS please dont forget to rate this thread.
Oct 18, 2006 | Samsung HLM5065W 50" Rear Projection...
Televison & Video Logo
158 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
