Question about Sansui COM3101 13" TV/VCR
Audio muffled when playing back video tape
When I play back a video tape on this unit, the audio is muffled. If I record a program on this unit, it plays back with regular volume on another VCR. The audio on the problem unit is fine when I am watching the TV. I realize that this unit is over 5 years old but I would like to know if the tape audio is fixable since it is my workshop and is used on a daily basis. Hate to buy a new one if I don't have to.
  • m3forus Feb 06, 2009
    Thank you so-o-o-o much!!!!!!!!!! After the third run of the cleaning tape the audio is crystal clear when playing a tape.
  • Sansui Master
  • 520 Answers
Have you tried using a wet type head cleaning tape? If not, run one thru at least 3 times.
Posted on Feb 06, 2009
Long play tapes are not recognized?
clean the heads, rotating head and audio head need to work together to read the speed of the tape also when recording there is a code it needs to read that is just out of the audio range on the tape and this is where the dirt from the tape can build up lp and xp use this area, standard play uses audio. but they all controlled by a processor to control motor speed.
Jan 04, 2018 | ION Audio VCR2PC VHS VCR
Audio noise on some, but not all VHS tapes
First thing i would say is go for the HI-FI audio would go in and out and pop etc. Adjusting the tracking would bring in the audio, but sometimes the video would get fuzzy. Get the picture right and the audio goes out. Switch to Linear (mono on some VCRs) and the audio should be fine.
Finally if this doesn't solve your problem then i would suggest you to give it to repair and they will fix it.
Goodluck..
Feb 16, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Won't record and play sounds muffled
Muffled sound is either damaged media (is it mostly the Left Channel? Multiple tapes or not?) or dirty Playback Head. Clean the heads and transport.
Please define better what "won't record" means. Tapes to be recorded need to have the little tab in the corner of the cassette shell present to allow the machine to enter record mode.
Feb 19, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
VHS won't play correctly - no picture, muffled low voices
Several things.
Check the tape, by opening the cover, to see if the tape is damaged. Look for signs of crinkling at the edges. This is often caused by the roller being worn on one of the VCR.
If it's damaged there's not a lot you can do.
If there's no damage try taking it out of the cassette box and fitting it in a new 'good make' blank tape tape box, discard the new tape in it. Still no good?
Next step, is the tape a movie/tv made by a commercial company. Or a recording on a blank tape?
Did it ever play? (if a movie) if not suspect a pirate tape report seller to FACT.
If a blank tape, try recording on a blank section. If that doesn't work and your video will record on other blank tapes. The tape has something wrong with it.
Some video recorders will play tapes with bad problems IE bad tracking, that others refuse to play, but you will either have to find one owned by a friend or buy one with that claim.
Sep 08, 2009 | Televison & Video
Audio vs. video picture
LIKE BELOW FOR INSTRUCTIONS
http://www.sony.co.uk/view/ShowProduct.action?product=RDR-GX120&site=odw_en_GB&pageType=manual&category=DVD+Recorder
Apr 29, 2008 | TDK T 120HS VHS Tape
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
Recording problem on Sony SLV-R1000
The deck needs a good cleaning. Try using a brand new tape and run it on playback for 20 min or so. You could try using a cleaning tape, but many of them are abrasive. If this doesn't work, you need a deck re-alignment which will cost more than your set is worth.
Nov 13, 2007 | Sony SLV-R1000 S-VHS VCR
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
Audio
Does it play back professionally prerecorded tapes okay? Does that VCR have a HiFi stereo option? What is the brand name and model number of the unit?
Apr 24, 2017 | Panasonic PV-C1331W 13 in. TV/VCR Combo
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sansui COM3101 13" TV/VCR Logo
77 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
