Back to:
Tags:
RCA D6520
2.5 dual tuner problem
By Odud - usenet poster
I keep getting a message saying the 2nd sattelight signal can't be
found.
I go into setup and check signal strength and whammo... it's there.
I go back to the guide and all is well.
I know how to fix it but it's kind of a pain in the butt.
Is there something wrong with my setup that could be causing this?
I have a Hughes GCXbot and am using the RCA D6530 multiswitch to feed
the tivo and a second receiver in the bedroom.
Thanks for any help,
Z
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Brad
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
did you remember to change the type of dish? You have to change it to the
appropriate type dish (forget which one I did just last weekend) but it's
like one of the first few choices.
T
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 2.5 dual tuner problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Kim1
Rating: 0%, 0 votes
I've heard of this problem occurring occasionally when using
non-powered multiswitches. These multiswitches draw their operating
power (for the switch itself, and for all of the LNBs) from one or
more of the receivers. In some cases, the receiver or receivers
providing the power can't provide enough, either due to receiver
limitations or to excessive voltage drop in the coaxial able. In
these cases, when the primary receiver changes its LNB drive voltage
(to switch to a different polarization sense) the multiswitch and/or
other LNBs lose power for a moment, and suffer a glitch.
The surest way to eliminate this problem is to use a multiswitch with
its own (wall-wart) power supply.
For non-powered multiswitches, it can help to try switching the
receivers to different ports. I believe that some multiswitches draw
most of their operating power from the receiver on jack #1, and it can
help to make sure that the receiver on this jack is a newer model (the
multi-satellite-capable models tend to have more robust LNB power
supplies).
Dave Platt
Visit the Jade Warrior home page: #
I do _not_ wish to receive unsolicited commercial email, and I will
boycott any company which has the gall to send me such ads!
Thank You!
Solution #3
Not Rated (0)
paulrmc
Rating: 0%, 0 votes
I am having a similar problem with my D6520. In my case, it appears that
the switching relays are contaminated or going bad. Sometimes when I change
channels that cause the multiswitch to change LNB ports, the (non-TiVo)
receiver will show "Searching for satellite signal". If I jump to the
previous channel then back to the new channel, the signal comes in. It's
like the relay needs to be exercised.
If I plug directly into the LNB, I never see this problem.
-Joe
Thank You!
Solution #4
Not Rated (0)
maartenw
Rating: 0%, 0 votes
Check your cables. I had a cat bite into one of mine, and that caused
enough damage to get me that message.
Thank You!
Solution #5
Not Rated (0)
paulrmc
Rating: 0%, 0 votes
Is your multi-switch powered? If not, how long is your cable run? Generally
the multi-switch should be powered if you have more than 100 feet of
cabling.
Thank You!
Can you Help with these Networking Hubs and Switches problems?
Attansic L2 Fast Ethernet Adapter je ne peut pas trouver...
which port may i use for GS8100 Router configuration with...
I'm using an 8 port hub and two laptops with MS Server...
Have a Dell PowerConnect 6248 layer 3 with 4 VLANs...
What is the host name or ip to acces Radware Link Poof,...
Loading problems.
Repair Service
Find Networking Hub and. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
