Question about Canon PowerShot A85 Digital Camera
E18 ERROR I have a Canon PowerShot A85 camera. The screen goes balck and I get the error. I have read that the lens could be stuck becuase of sand, etc. But, I have tried what the blogs have told me and I still get the error.
  • Dave Knibb
    Dave Knibb Feb 08, 2009
    My lens started to come out when switched on in picture-taking mode, but stuck halfway. E18 comes up in corner and camera won't do anything else.
  • 4 Answers
Canon camera hard work just
check your lens
see if the memory card is full or not
Posted on Feb 06, 2009
Canon PowerShot A510 error code E18. What does it mean?
Canon E18 error happens when the lens gets stuck while trying to extend. The problem usually happens because dirt or sand get into the lens mechanism. If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
Jul 11, 2011 | Canon Cameras
E18 screen msg
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 17, 2009 | Canon PowerShot A85 Digital Camera
My lens for my canon powershot SD550 is stuck open.when switching the camera power on E18 appears on the screen in the bottom left corner.
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here are some things that you can do to try to correct it. They only seem to work for about 40% of lens errors, but if the camera is out of warranty they're worth a try.
Nov 15, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
My camera is showing E18.I can't take photos. What
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 30, 2009 | Canon PowerShot A85 Digital Camera
Error code E18
Lens errors (aka E18 errors for Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Dec 20, 2008 | Canon PowerShot A95 Digital Camera
I have a powershot A85. Lens wont retract. Camera cuts off after about 10 seconds. Bottom left corner reads e18 just before it turns off.
this is a popular error due to dust or sand in lens assembly
search google for e18 solutions will flood
Oct 21, 2008 | Cameras
Canon powershot s2
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 01, 2008 | Canon PowerShot S2 IS Digital Camera
There is warning (E18)on screen of my dijital camera canon powershot A75
Feb 01, 2008 | Canon PowerShot A75 Digital Camera
E18 ON SCREEN
first tell me at this problem are your camera's lens woring properly or not
Oct 18, 2007 | Canon PowerShot A85 Digital Camera
Canon e18 error
error code e18 means that the focus motor gears a jammed, dirt or grain of sand in them. you can try to fix it by gently banging the camera on somthing soft, their are also instructions on web on how to disasemble and fix this fault. BUT unless you have some skills, the right tools and conditions i would not attempt it. leave it to the experts. their are several flat cables, without actually seeing I cant tell you
Aug 30, 2007 | Canon PowerShot A85 Digital Camera
Canon PowerShot A85 Digital Camera Logo
89 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
