Question about Toshiba Equium 7100S PC Desktop
Toshiba Equium Laptop keyboard not operating correctly
Is there a problem with this model??
Some keys not working when I received the laptop. Keyboard immediately replaced by supplier (PC World UK)
Replacement seemed to be ok and immediately took it abroad for the winter, then I found that say 2 keys will not type without some pressure, these will then rectify without any modification, and then one or two different keys will become faulty.
  • davcross_1 Feb 06, 2009
    Thanks for that though its not the news I wanted to hear!!
    President:
  • 1,902 Answers
There has been a lot of talk around this computer lately about the same problem you are having. It has something to do with the plug that plugs into the mother board it self.
Posted on Feb 05, 2009
  • Jeremy Reddick
    Jeremy Reddick Feb 06, 2009
    I know, I am sorry to tell you that but I would rather you know the truth and not have someone fill your head
How do you fix computer keys?
If you are talking about a separate keyboard just buy a new one....they are cheap. Some things are just not worth messing with and this is one of them.
Jan 14, 2017 | Computers & Internet
How do you clean to factory settings a fujitsu laptop
You must do a full system recovery. Go to the manufacturers website to see how to do that on your model and operating system.
Jan 12, 2017 | Fujitsu Computers & Internet
E130se how to write in upercase letter
use the shift key and the letters you wish to type .
Jan 11, 2017 | Computers & Internet
Screeen is upside down
If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
I hope this helps.
Jun 01, 2014 | Computers & Internet
How do I get the battery out of my acer laptop
Your Model of Aspire has a different battery release method, see attached pic on how to do it. This is a pic from your User Manual, you can download it from here Download Acer Aspire E1 572
Manual
. I suspect that the information you have been given regarding battery removal and passwords refers to removing the cmos battery as in a PC in the hope that it will clear Bios activated passwords.
May 04, 2014 | Computers & Internet
Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
Mar 21, 2014 | Computers & Internet
I've a acer laptop model no 4820T. In this touchpad option not working but left and right button was working.... wats the problem n wat to do? tel me soon............."
Try the following: Using your FN key and the F7 Key together it might work again. You could have toggled the touchpad off. If that does not work you have issues with either the touchpad or the operating system. Best of Luck.
Sep 14, 2013 | Computers & Internet
P850 049 laptop
Take it back to the place of purchase and get a replacement as it is under warranty.
Do not try to fix it yourself as you may void your warranty.
May 15, 2013 | Computers & Internet
How do i reset my computer to an earlier date?
Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
Jul 27, 2011 | Computers & Internet
Mouse and keyboard have no power
If your mouse and keyboard work properly with another computer or laptop the problem could be :
A) if devices are USB :
- defective USB port : chose another USB port;
- USB port inactivated in BIOS : check and activate;
- motherboard defective : replace motherboard.
B) if devices are PS/2 :
- damaged PS/2 ports : buy a PS/2 to USB adapter for your mouse/keyboard or buy USB mouse and keyboard;
- motherboard defective : replace it.
Oct 04, 2009 | Computers & Internet
Toshiba Equium 7100S PC Desktop Logo
414 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
