Question about NEC Electra Elite DTU 16D-2 Corded Phone
Telephone display reads "initialize" Whats up?
Upon unplugging the phone, and installing a new cable, the phone reads Initialize, do I need to do something to get it to work agian?
  • Eric Conrad May 11, 2010
    The "Initialize" indication only means that the pair of wires to the phone have some voltage on them. If the phone never does come up, it means that the data to the phone from the digital station port back at the main cabinet is either non-existent or degraded too much for use. Make sure you are wired to a digital station port and not any analog connection. Also, remember you cannot run two digital instruments from of a single port. It is slightly possible that you may have electrostatically shocked the circuit. You may cure this by a system reset.
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
I m getting c6 code on my msi motherboard 7642
Hello here is the homepage:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Manual
Make sure ALL the drivers is installed on the mainboard:
http://www.msi.com/product/mb/890GXM-G65.html#/?div=Driver&os=All
Post Status
FF Power on and first initialize CPU.
C0, C1, C2 Early CPU Initialize.
C4, C6 Initialize chipset.
D4, D5 Initialize memory.
08 Initialize keyboard.
2A, 31 Initialize onboard devices. Load Option ROM (VGA and RAID
option ROM) form BIOS to memory.
37 Displaying sign-on message, CPU information, setup key
message and any OEM specific information.
38 Initialize USB device and different devices.
3C Mid POST initialization of chipset registers. Detect different
devices (parallel ports, serial ports and coprocessor in CPU...etc.)
75, 78 Initialize INT 13 devices and IPL devices. (include SATA/ PATA
HDD and CD/DVD ROM).
87 Enter setup screen. BIOS setup if needed/ requested.
A4 W ait for user input at configuration display if needed.
A7 Display the system configuration screen if enabled.
B1 Save system context for ACPI (Advanced Configuration and Power
Interface). Prepare give control to OS loader (INT 19H).
00 Pass control to OS Loader (typically INT 19H).
AA Enter OS (Vista or W indows XP).
Look also here:
http://www.dewassoc.com/support/bios/awardbios_error_messages.htm
Did you upgrade the ram memory, or the cpu ??
When and how did this problem occur ??
Jan 31, 2013 | Computers & Internet
DVD tray is locked, how to unlock?
Step 1:
Initialize unit by simultaneously pressing Back Skip, Pause and Open/Close on the front of the unit. "INITIALIZE" should now appear in the
display and will remain in the display for a few seconds.
Step 2
With "INITIALIZE" still in the display, now simultaneously press Back Skip, Stop and Open/Close on the front panel. "ALL SET" should now appear
in the display.
Dec 23, 2010 | Panasonic DVD-RV32 DVD Player
When new Compact Flash Card installed in Fuji S7000 display says "Card not initialized" How do I initialize card/
Go into the menu and find "format" (or it may be called "initialize")...follow the on-screen instructions.
Sep 27, 2010 | Fuji FinePix S7000 Digital Camera
I cannot get the cartridges into the position to replace. The new black one is not printing,i did a nozzle check and clean and decided to replace the black butred and green lights are flashing and the...
There is no standard ways to replace the cartridge of this printer so better follow these instructions to remove the cartridge and replace it. You will need to unplug the power cable of the printer as quickly as possible after the cartridge leaves its home base position when it moves to initialize after being turn on.
  1. Turn On the printer.
  2. Unplug the power cable from the printer when the cartridge carrier left the home base position to move to the other end. (Look and see inside the cartridge carrier, when after turning on, it will initialize, the cartridge carrier will move from one end to the other end. Just as about to move in the center unplug quickly the power cord)
  3. You can now freely remove the cartridge and replace it.
  4. After replacing, push the carrier to its home and reinstate the power cable.
  5. Turn on the printer and allow to initialize
Please rate this answer. Thanks.
Aug 11, 2010 | Epson Stylus C62 InkJet Printer
LaserJet 2840 Printer: I am trying to initialize a new drum. An error mes...
This means that the printer cannot read the E-Label on the cartridge, or it is not properly installed.
  1. Reinstalle the cartridge
  2. Power cycle the device
  3. If the problem is not solved, replace the cartridge. (Is the cartridge a remanufactured one? this can be a problem)
  4. Check if correct cartridge type.
May 10, 2010 | HP LaserJet 2840 Printer
Failure to initialize after a microsoft update was installed
Go into the control panel and find the device manager. Then locate the UPS unit and right click and update driver. Then pick roll-back driver. This should install the prevous driver that was working properly. Then when you do windows update make sure to set it to hide that update so you don't re-install it again.
Sep 26, 2009 | Cybernet Systems CyberPower CP1200AVR...
Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
LG Viewty pc connection problems
I had the same problem. It was caused by the phone waiting for the date to be entered (even though it was already done). To get over the problem click on the multitask icon on the phone (top right). If anything is running other than "Home Screen" and "Menu" click on the application and close it. PC synchronisation should strat to work now.
Dec 30, 2008 | LG KU990 Viewty
Nokia 6630 not able to initialize
better uninstall tat software nad download kaspersky in jar or sis file format...then upload in ur mob and use it
Jul 06, 2008 | Nokia 6630 Cellular Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
1,360 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
Oloyede Monsuru
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
