Question about Canon PIXMA iP1600 Printer
Cant load paper into yhe printer
Paper is loaded in loading area and wont feed
    Problem Solver:
  • 11 Answers
Check if there is a paper jam
Posted on Feb 18, 2009
My Kodak printer wont grab the paper in the paper tray
Amandasplace:
There is a sensor that is located where the front edge of the paper sits when you load paper. If you take all of the paper out of the feed tray and use a flashlight to look in the throat of the paper feed area, you should see a small piece of plastic (in the shape of a blade) sticking up. If you do not see that sensor flag it may be broken off, or there may be a small piece of paper jammed against the sensor flag, keeping it from moving downward when you load the paper tray. That can happen if you pull a mis-fed piece of paper out of the machine in the opposite direction that the paper normally travels when printing. When you load the paper in the machine, it pushes that sensor flag down, telling the machine that there is paper loaded. either the sensor flag is broken off or there is something jamming the paper sensor, keeping it from being pushed down by the paper.
Nov 23, 2012 | Kodak ESP Office 2150 All-in-one Printer
ADF wont feed the paper through the printer
You can load up to 30 sheets of plain paper in the Artisan 800 ADF. If the ADF doesn't feed the paper, check the following.
1. Make sure that you are loading plain paper only without a holes. 3-hole punched paper is not supported by this printer.
2. Load paper not exceed 30 sheets.
3. Open the ADF and check for any jammed paper or foreign object that is blocking the paper feeding path.
4. Check if the BIG GREEN ADF indicator is lit when you load paper in the ADF.
If the issue persists, your printer will require service. You can contact the Epson for warranty if your printer still under warranty. If your warranty expires, look for an a service center that can repair your printer.
Oct 29, 2011 | Epson Artisan 800 All-In-One InkJet...
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
Paper won't feed. It's in the back stand up area
i have had this problem with a few Lexmarks. try a lighter weight paper or lessen how much your loading into it. also make sure nothing is in the bottom of where you load the paper (example: there is a pencil in there and the paper is sitting on the pencil) If its new take it back and exchange it. when it loads the paper the bottom of the tray tilts forward. that may be faulty.
Oct 21, 2009 | Lexmark Z1320 InkJet Printer
Paper wont load
Check the feed rollers, (IF you do a alot of printing), the feed rollers are slick with paper dust, and are causing the jam, You can clean tyhem by taking out the paper, and clean the roller with a cloth rag and some 409 cleaner. scrub the feed roller to remove the paper dust, then let the rollers dry, then re load paper and begin printng
Jul 21, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Paper will not feed
its a software issue for me..
I suggest that you will load compatible firmware to your printer...
that's why the printing performance of your printer is very slow..
thanks for using FIXYA.
good luck.
May 21, 2009 | Lexmark X83 All-In-One InkJet Printer
C 4180 photo smart printer, not loading 4x6 photo paper
You could try stacking more paper behind it, thereby creating more pressure on the paper feed.
May 06, 2009 | HP Photosmart 4180 All-in-One Printer
PAPER WONT LOAD
Greetings,
I beleive troubleshooting with simple proceedures. Try alcohol on the rollers and Canned air in the paper load area. Trust me it works.
Regards,
techSup1
May 01, 2009 | Dell 946 All-In-One InkJet Printer
After you load paper printer says no paper loaded. It catches paper but does not send it through.
YOU HAVE FAN THE PAPER BOTH ENDS LONG WAYS FAN THE PAPER, WIDE OR SIDE OF THE PAPER NEEDS TO BE FANED,
ASSIST THE PAPER INTO THE FEEDER MAKE SURE THERE IN NO FORIEGN OBJECT IN THE FEEDING AREA MAYBE PENCIL OR PEN FELL DOWN THERE,
STICK YOUR HAND BEHIND THE PAPER AND PUSH THE PAPER FORWARD UNTIL PAPER STARTS TO FEED YOU HAVE TO DO EVERY TIME YOU LOAD NEW PAPER UNLESS YOU PLACE NEW PAPER BEFORE IT RUNS OUT OF PAPER, THIS IS A PICKUP ISSUE FOR THE PRINTER,
ROD
Feb 02, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper wont load
You can try cleaning the rubber paper feed rollers, located where the paper feed into the printer. Use a rag moist with rubbing alcohol and rub all rollers thoroughly and this should help. Good luck John
Sep 12, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA iP1600 Printer Logo
129 people viewed this question
old marine
old marine
Corne Viljoen
