Question about Dell Latitude D610 Notebook PC
DST result fails
When tried to take DST test for booting the laptop, the test failed.. please help Hi there,
I had the same problem for the first time on my Latitude D610. My computer had been in standby; when I tried to resume, the screen was black with no apparent CPU or hard drive activity. On restarting, my BIOS informed me that one of my memory sticks was corrupted and couldn't be used (they've been working fine for years).
Restarting again seemed to indicate things were a-ok again, but I ran the diagnostic check to be sure. Memory passed the test just fine, but it failed the "DST Short Status Test" almost instantly, with "Error: 1000-0142", Message Unit 4, and status byte 70.
I mention all this because I'm actually writing this post on the same machine! Startup continued just fine after the diagnostic and I've no apparent issues in Windows (memory is as it should be). Chkdsk has turned up about 15 bad indices, but this isn't too uncommon.
So depending on the actual DST Short failure, you may not need to get a new drive (though that would certainly be a workable solution). Do you have data on the drive you wanted to save?
  • 38 Answers
I would say this is the memory. You said that you checked the memory, and it passed, but did you download a cd called 'memtest x86' ? This will definately make sure your RAM isn't cooked. You boot off of this disc and let it go for a couple hours, it will tell you if it finds errors. Also, if it's the harddrive, you can just replace the harddrive, and then hook it up via USB and retrieve your information.
Posted on Feb 05, 2009
Dst short test fail error code 1000-0146
DST stands for Drive Self Test, if it fails the test it means your drive is failing or has failed. replace hard drive
Jun 02, 2014 | Dell Latitude 100L Notebook
DST Error 0146 Help me to fix.
Well DST means "Drive Self Test" which indicates that your HDD is failing. have you dropped your laptop by accident recently? If so, open it up and see if any of the cables are loose.
Do you still have your original Windows OS Disc? If you do then you could try booting the
recovery console and run chkdsk /r
Hopefully you can get windows to boot, and you can backup your data
Nov 11, 2010 | Dell Inspiron 6400 Notebook
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
Error Code: 1000-0146; MSG: Unit 0:DST Log contains previous erro
Code 0146 is hard drive read/write failure.
Replace the hard disk drive
Jan 27, 2010 | Dell Inspiron 6000 Notebook
I have a dell studio 1737 laptop i purchased in Feb of this year. my computer works for about 10-15 minutes then crashes completely. i went into safe mode and found that the consumer IR devices will not...
0F00:065D is a hard drive read test failure. the hard drive is failing. If purchased in Feb, the system should be under warranty call Dell Tech Support to get a replacement hard drive. (800-624-9896 in USA)
If out of warranty you can get a 2.5 in SATA HDD at Newegg.com for about $60
Dec 05, 2009 | Dell Studio 1737 Laptop
Failed DST Short Test and Screwy Mouse/Keyboard
Hi there.
I'm sorry to say that error code 1000-0146 means that the hard drive is failing and it can go at anytime, get yourself a USB mouse and start the computer up, the operating system should recognize the mouse and install the drivers (it may take a couple of minutes so be patient), as soon as the mouse is installed it is imperative that you back up all of your data, either to an external drive or CD/DVD.
Then you have to purchase another dive of if you have any warranty on the laptop send it in for Dell to repair.
If you are out of warranty and need instruction on how to install a new drive please feel free to post back.
Good luck and thanks for choosing FixYa!!
Jun 05, 2009 | Dell Inspiron 6000 Notebook
Dst test fail ie freezes up many times it says loading but never
you need to boot your laptop in "safe mode" then use the system restore function to restore your laptop back.
May 28, 2009 | Dell Inspiron 6000 Notebook
DST result fails
DST test is for Hard Drive - if this test failed, you will need to buy or contact technical support for a replacement Hard drive.
Hope this helps!
Jan 11, 2009 | Dell Latitude D600 Notebook
Dell latitude d600
Greetings AROD718,
This error message is telling you that your hard-drive is nearing OR has already failed.
I would contact a buddy or go somewhere local to get Data recovery ASAP or if that is not important to you start shopping for a new hard-drive.
Hard drives are not very expensive and are simple to install, if you need further assistance please reply back!
Good luck,
Shawn
Oct 31, 2008 | Dell Latitude D600 Notebook
Dell Latitude D610 Notebook PC Logo
342 people viewed this question
Alun Cox
