Question about Samsung ML-2510 Laser Printer
How to Print an Envelope
Can't figure out how to print an envelope on this printer. I have no user manual.
User manual should have been installed with the software that runs the printer from your computer. My WindowsXP system has a main menu item for the printer. Mine says "Xerox Phaser 3124", but it's really the same as the Samsung 2510.
When you go to print, select the printer, then the type of paper (envelope). This can be done by going to printer properties and then the layout and paper pages. You will want to insert the envelope just above the stack of regular paper, in the single sheet feed area.
Posted on Feb 20, 2009
How can i print an envelope
Instructions for printing envelopes can be found on page 64 of the user manual. If you do not have a copy, download one from here:
http://h10032.www1.hp.com/ctg/Manual/bpl10395.pdf
Mar 28, 2015 | HP LaserJet 1200 Printer
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a brother HL-2140/2170W Monochrome Laser Printer and don't know if I can print envelopes from this printer. It doesn't appear to have an envelope feeder.???
It can cause creased envelopes when printing on envelopes......but if you consult the manual there are fuser tension adjustment switches that solves that for perfect envelope printing (Settings, A, B and Envelope).
http://www.iusermanual.com/printer/brother-mfc-9840cdw-multi-function-printer-manual.htm
hi at this above site you can download your user manual, this shows you in detail exactly how to print on envelopes.
below is a Brother "How to" It's very informative.
http://welcome.solutions.brother.com/BSC/public/as/nz/en/faq/faq/000000/000000/000063/faq000063_033.html?reg=as&c=nz&lang=en&prod=mfc9840cdw_all&Cat=103
Dec 20, 2010 | Brother MFC-9840CDW Laser Printer
Print envelopes brother 2040
Ummm... Just go to the user manual. It will show you how to do this. It's really not hard. Manually feed the envelope into the printer (that thing on the front that you can play with and the sides get closer, and further apart at the same time) You'll need to have word set to print on an envelope. Again not hard just a little bit of know how. Google "word envelope print" and you will find instructions on how to set up word.
Sep 23, 2009 | Brother HL-2040 Laser Printer
How to print envelope on Panasonic DP-2330 printer
You can download a user's manual from here.
It's a pretty large file, so I'm guessing there's something there about paper feeding or envelopes that will help you.
Good luck.
Aug 31, 2009 | Panasonic Workio DP-2330 Printer
When we try to print envelopes. It grabs the
Open the door on the back above the power cord. Rotate both blue levers all the way up so they change from "1" to "2". Wrinkle problem will be solved. This was in the troubleshooting section of the online user manual, page 95. You would think they would tell you about this in the envelope section of the manual.
Jul 01, 2009 | Brother HL-5240 Laser Printer
Pixma MP 970, how can I get manual
Here is the downlink for the Installable Manual. Download this where ever you chose so you can find it later if needed. Once it is downloaded, double click the file to unpack the data. Once that is unpacked click on Start and it will install to your Desktop. I found the below data from the manual. The manual looks very complete.
These instructions are directly from the Manual:
Printing an Envelope Printing an Envelope For details about how to load an envelope into the printer, see the user's manual.
2. Load the envelope in the printer.
When loading the envelope in the cassette, orient the envelope so that the flap is on the left and folded surface is facing up.
6. Click OK.
I hope this fixes you up and you get the manual downloaded. You many need to start here just in case and select the entry for the Manual in English.
Best Regards,
Worldvet
Jan 11, 2009 | Office Equipment & Supplies
How to print envelopes
Put envelope in bypass tray. Print on it.
Jul 23, 2008 | Brother Office Equipment & Supplies
Address envelopes correctly
I'm running Vista and I thought there MUST be a way to print envelopes! So, this is how I figured out how to print envelopes perfectly! No doubt, this would be how the manual would instruct, but it's apparent that none of us are able to locate our printed copies, right? Guilty as charged!
Slide paper tray out; remove paper you have loaded in your tray. Set envelope in tray (face down, with top of envelope flush left) and adjust both side bars (designated as "1" in paper tray diagram - visible when all paper is removed from paper tray) so that they are flush against envelope. Slide back bar (designated as "2" in paper tray diagram - visible when all paper is removed from paper tray) so that it is flush with edge of envelope. Click print.
Believe defaults are set to #10 envelope. Envelope options - check / click on the following: face up, clockwise rotation and "Feed from" Auto Select. Click on / highlight the 5th envelope depicted in the top row of envelope examples.
Jun 16, 2008 | Brother Multi-Function Center MFC-240C...
HHow do I print envelopes on a deskjet940c. What is the set up.
Here is a how-to for the printer, but I'm not sure if you mean the printer, or in a program.
If this is not what you need, let me know.
HP Deskjet 920c and 940c Series Printers - Printing Envelopes s.gif s.gif s.gif
gtabblt.gif Loading a single envelope gtabblt.gif Loading multiple envelopes gtabseps.gif Loading a single envelope Preparing to print
  1. Place the envelope, with the flap side on the left and facing up, into the single envelope slot.
  2. Push the envelope forward until it stops. See Figure 1.
Figure 1: Inserting the envelope c00104463.jpg Printing guidelines
  • Verify that the Out tray is in the down position.
  • Avoid using envelopes that have clasps or windows.
  • Avoid using envelopes that are shiny or embossed, envelopes with thick, irregular, or curled edges, or envelopes that are wrinkled, torn, or otherwise damaged.
Loading multiple envelopes Preparing to print
  1. Pull out the In tray.
  2. Slide out both paper guides and remove all paper from the tray.
  3. Place no more than 15 envelopes -- with the flap side on the left and facing up -- in the tray.
  4. Push the envelopes forward until they stop.
  5. Slide the paper guides snugly against the edges of the envelopes, then push the tray forward until it stops. See Figure 2.
Figure 2: Inserting multiple envelopes c00104464.jpg Printing the envelopes Each software program is different and requires different steps to successfully print envelopes. For instance, in many versions of MS Word, clicking Tools , and then Envelopes and Labels , accesses the envelope-printing feature. Other software programs will differ from this procedure. Consult the Help menu on a software program or User's Guide for instructions for the particular application. Printing guidelines
  • Never place more than 15 envelopes in the In tray at one time.
  • Align the envelope edges before inserting them.
May 27, 2008 | HP Office Equipment & Supplies
Samsung ML-2510 Laser Printer Logo
245 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
CheckitRight
CheckitRight
Paul King
Paul King
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
