Question about Alesis 16 Bit Stereo Drum Machine System
Alesis SR-16 Battery holder
I have an older Alesis SR-16 that must have had the battery holder removed. Does anybody know where there is a circuit board diagram available on the internet, or what type of battery holder goes in it?
  • Anonymous Apr 05, 2009
    when i opened mine up...it has a rigged up contraption with paper clips and solder and the wrong holder and a different battery
5 Suggested Answers
SOURCE: need foot switch for this machine.
What you need is 2 unlatched switches 1 for the stop start function and one for the drum fill function.
I bought mine from my local music shop for £15 ea
Posted on Jul 13, 2009
  • 5603 Answers
SOURCE: Alesis-sr 16 sound low
Buy the correct adapter that matches the voltage AND current requirements of the unit. MANY universal ones do not and the original MAY have built in filter that universal does not.
You MAY also need to do a factory reset on the unit.
Posted on Oct 18, 2009
Testimonial: "Many Thanks!"
djlaplaya
  • 74 Answers
SOURCE: how do i dump midi user patterns from alesis sr 16
you may well have to go via a third unit, a computer or laptop to store the data then send it back to the other machine.
Posted on May 06, 2010
  • 5603 Answers
SOURCE: HI , MY ALESIS RS-16.
Cut and pasted info to replace the internal memory battery:
There is a battery inside the unit which is used to retain settings and beats that you program into it. This battery should probably last about ten years or so. If your SR-16 will not remember things anymore, it may need a new battery. Alesis can replace it for you, but this may cost $50.00 or so plus the cost and trouble of shipping. Anyone who can use a soldering iron can replace the battery. To disassemble the SR-16, remove the six screws on the bottom. There is a ribbon cable that connects the top and bottom together. This should be unplugged from the bottom part (main circuit board). The pins on the connector are very fragile, so pry it up carefully with a screwdriver. Also the volume knob has to come off. To remove the circuit board, just unscrew the nuts on the six phone jacks on the back. The battery is a coin-shaped 3-volt lithium battery. The one in mine is a Panasonic BR2325. If you buy a replacment battery, you will need to get one that has PCB terminals on it so it can be soldered. I THINK this is Panasonic part number BR2325-1HB (theres lots of different types of connectors on these). You will not find this at Walmart. It will need to be ordered from an electronics supply place. Digikey has them for $2.00. I think you can get one from Alesis for 15 or 20 dollars.
Posted on Aug 07, 2010
  • 8 Answers
SOURCE: What is the factory reset procedure for the Alesis
hold down erase and play as you power up
Posted on Aug 17, 2010
Hello I recompose my question. J would like to know the value of the ceramic condenser close to connector VAC of the circuit of Sr-16. On the circuit C5 opposite the condenser is written. it is round
You might try going to this webpage
https://www.alesis.com/sr16
and from the docs&downloads section download and search the Reference manual. It's also here http://www.burnkit2600.com/manuals/ALESIS_SR-16_OM.pdf (this looks more like a user guide though)
Failing that, choose 'support' from the th top of the page and either contact Alesis support or else ask your question in the 'community' (which you will have to join). Another community which deems to have an interest in the SR-16 is www.circuitbenders.co.uk but I think it unlikely that they could direct you to a circuit diagram, though it is slight possibility that someone might know the value of the capacitor C5
23.December.2014
Dec 23, 2014 | Alesis Sr 16 Stereo Drum Machine
ALESIS SR-16 won't save patterns
Really Quick.
Two problems are unrelated.
Assume older unit.
Needs memory battery,
and new display.
Nov 08, 2014 | Alesis Sr 16 Stereo Drum Machine
Alesis sr 16 service manual
I got a service manual but don't know how to get it to you. I can sent it by email. Let me hear from you. Contact: petevanderwaal@yahoo.com (subject: "Manual")
The manual is for Alesis HR-16B SRV comes in PDF format.
Aug 19, 2014 | Alesis Sr 16 Stereo Drum Machine
When i disconnect power I lose user settings
Likely the backup battery is exhausted. Some of these are in a battery holder, others solder into the board with tabs. Measure the voltage of the cell. If less than 2.75 volts replace it. The cell will likely be designated something like BT1.
Apr 04, 2010 | Alesis Sr 16 Stereo Drum Machine
Ihave an Alesis D4 drum sampler.I have not used in several years I have hooked it up now an everything lites up but I cant get any sound out of it. with triggers or pads?
Some of the Alesis products have a setup and data memory backed up by a battery. It is POSSIBLE that your battery expired and took the sound memory with it.
Investigate if you have a battery in yours (buried in the guts) and check the voltage. It should be above about 3 volts.
If it is below that, replace the battery and find another unit to clone the data from.
Sep 23, 2009 | Alesis Sr 16 Stereo Drum Machine
Sep 16, 2009 | Alesis 16 Bit Stereo Drum Machine System
SR-16 gives message "ERROR: 01" when powering up
You likely have lost the internal memory data. This can be due to a power surge or that the internal battery has been depleted. The battery may need to be replaced.
You should reset the unit and reload the data, The manual is available online. Search Google for it.
The manual STRESSES the importance of backing up the data.
If you don'thave the backup, you MAY need to find another SR-16 owner to clone the data from.
Jul 01, 2009 | Alesis Sr 16 Stereo Drum Machine
Alesis 16 Bit Stereo Drum Machine System Logo
337 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
sonic boom...
sonic boom...
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
