Question about Cozy Heating & Cooling
Gas engineer wants to re-arrange coals correctly post service
Gas fire requires a service but gas engineer (not british gas)corgi registered will not touch the fire unless he can put the coals back on correctly
  • 1 more comment
  • robin_chilve Feb 07, 2009
    Hi paulcarew
    Thanks for your reply my problem is that i do not have a instruction manual.The gas fire is a cozymizer 1 can you or anybody help
    regards robin_chilv
  • Paul Carew Feb 11, 2013
    Best to google your make and model , or cozymizer , you can take pictures of the coals as theryare taken off its not that hard the lay out is simple
    look on focal piont gas fires
  • Cozy Master
  • 2,888 Answers
Yes he is right on that the postion off the coals have to be in the correct pstion to stop fire sooting and fumes coming from fire , if the coals are in postion you take them out and put them back the same as they came out , or there should be a picture of the coal lay out in the users book , or look on line for the make of fire , if the gas engneer cannot work this out then go to some one who can ,
this is basic gas fitting any gas fitter will know this if not walk away from them ,
hope this helps
Posted on Feb 07, 2009
  • 1 more comment
  • Paul Carew Feb 07, 2009
    do you mean a cosy miser 1 gas fire look on google it shows a inset fire there is also a help line number ,if this is the one they may well have a list of gas fitters who would do this work for you.
    hope this helps you .
  • Peter ward Feb 10, 2013
    I have a similar problem with cozymizer 1 but can't find the picture on the web. Do you have the web address?
  • Paul Carew Feb 18, 2013
    Google focal point fires
I need a manual for a cannon inset gas fire to see how the coals should be arranged. It's a cannon 26730g. needs servicing and engineer wont look without a photo /copy of how the coals go.
Google the make and model of heater or go to cannon wedsite for manuals The gas fitter can take a picture of the coals before starting the job its not that hard if he cannot do this the find some one else .
Oct 04, 2016 | Heating & Cooling
Where would you find the makers name on a gas fire which I have bought second hand. I need to establish how the 'coals' are arranged? My gas fitter can finish the installation. Thanks, Mark
look underneaththe fire it could be on a swing out lever or on a wire or onn ther bottom panel , your gas fitter should know where to look
Aug 09, 2010 | Heating & Cooling
Converting propane to natural gas
hi there..be advised do not attempt this conversion yourself....legislation requires you have this work carried out by a corgi registered gas engineer who will issue you a certificate for you home insurance......NO CERTIFICATE NO INSURANCE..&..YOU ARE PUTTING YOUR LIFE AND OTHERS AT RISK ..
Sir Galahad
Aug 24, 2009 | Dryers
Position of coals on a gas fire
Hi crosslee are on google they have a e-mail help line they should be able to send a pic of how the coals should go ,
Sep 30, 2008 | Honeywell Programmable Thermostat Heater
I have recently had a corgi registered plumber remove a gas fire with back boiler from my living room and he blanked off the supply as we no longer require a fire in its place. we also have installed a new...
IMMEDIATELY ISOLATE THE OVEN AND DO NOT USE. GET PLUMBER BACK - HE SHOULD BE ABLE TO CHECK THE APPLIANCE ITSELF FOR LEAKS BUT THE MOST LIKELY CAUSE IS THE JUNCTION OF THE CONNECTION HOSE WITH THE HOB
Sep 09, 2008 | Kitchen Ranges
My gas oven flame
BLOCKED JET MAYBE CAUSED BY FOOD SPILLAGE OR BLOCK IN PIPE TO JET
May 28, 2007 | Parkinson Cowan SG320 Gas Kitchen Range
Heating & Cooling Logo
2,431 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
