Question about Fisher and Paykel Fisher & Paykel Washer
Fisher paykal GWL10 top loading washer
Worked fine then started beeping when in SPIN - unplugged and reconnected after a while (twice) as recommended in troubleshooting guide of booklet. No error code will show. Will start SPIN with the usual DRAIN but the water drains back into the tub. I was able to confirm that the drum is attached, rigged container inside drum to drain most of remaining water and now it progresses with SPIN but since the water drains into the tub it won't complete. I believe it is a plugged up drain, not sure how to get to that part best.
Is there a way to get a schematic for this type of washer since it is a belt-free design not your usual standard machine?
  • Monika Schrauder Feb 06, 2009
    Thanks, Rescue Tech, for responding. Question: do I access the diverter valve by laying washer on its side and getting from underneath the tub or do I need to remove the tub?
    ms01007
    Hi Rescue Tech,
    I am new to the forum - your reply was absolutely detailed and very helpful, I thought the fixya follows when a member has fixed the problem. I will follow up with a rating, of course.
    ms01007
  • 145 Answers
Hi. I work on these machines every day.
The problem with your model 10 is that the diverter valve is not in the DRAIN position, so when the pump runs, it is sending the water right back into the tub. The issue is one of two things-
Either the tab on the diverter valve has physically broken off and the machine needs a new diverter valve, or there is a short in the machine's controller and it is sending a constant signal to that valve, causing it to never be in the DRAIN position. When the diverter is NOT energized, the flap is at rest and the water will go out the drain. When the valve IS energized, the water is supposed to go thru the recirculation hose.
You want to check that diverter valve first and formost. That's going to tell you what you need to know. Look closely at it and you'll see if the little tab that goes from the wax motor to the flapper lever is broken off. The diverter valve is located down underneath the tub in the right rear, it has three hoses attached to it and two wires. It's grey in color and the little wax motor is brown.
If you would like to obtain a service manual, you can get them from http://www.fisherpaykelparts.net
Posted on Feb 06, 2009
  • Greg Angeli
    Greg Angeli Feb 06, 2009
    Yes, you tip the machine back.
    I'm sorry you did not find my detailed and precise reply to be worthy of a FIXYA rating.
    I hope you are able to fix your machine. Have a nice weekend,
Gwl10 us won't fill
there's a few possibilities here.
is the water on?
does the machine start and turn the bowl, and not fill? then you have a valve fault.
when you press start, does it beep like normal? if not, you have a start button fault.
Oct 15, 2013 | Fisher and Paykel IWL12 Top Load Washer
Fisher & Paykel GWL10 begins to spin for about 15 to 20 seconds, just starts to pick up some speed, then machine beeps and shuts down. Seems like the water is draining. Any ideas? It has also been...
Yes it does seem like a control module fault.Bit concerned about the noise coming from the machine even thou it is not running.Please turn it off at the power point when not in use.Now if and when it faults again please reply back with error code as per 1st posting.
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel gwl10us wont fill
Both of you most likely are getting a "RPS Sensor Fault"
On a GWL10, when the motor rotor position sensor fails, it will act exactly like you describe. Many techs incorrectly replace the machine control or the water inlet valve(s). The RPS sensor is much cheaper. If you consult the tech sheet located under the control panel, you will see the fault code for RPS failure and I would bet the farm that the sequence of LEDs displayed when your washer faults out matches exactly with the RPS fault code.
The RPS sensor for GWL10 and GWL11 models is a part # 420296P and canbe purchased direct from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=5
The procedure to replace it is a little involved but a handy person can do it. It would be best to consult the factory service manual and again, that can be purchased from Fisher Paykel Parts direct here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=15
Nov 25, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL10 US won't spin
its possible that the pump is either going bad or there is somethin gin the pumps/sump assy. on this model the unit generally tends to shut down when the pump overheats, and will only restart when the pump cools off, a warnig obout replaing hte pump if need be is the pump is actually 220v. you MUST UNPLUG MACHINE BEFORE SERVICING. its a foriegn brand remember so theres abuncha wierd wiring and the pump is one of them!
Mar 25, 2008 | Fisher and Paykel IWL12 Top Load Washer
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
Sep 16, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Sep 02, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
702 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
