Question about Maytag Washing Machines
Knocking sound in the spin cycle off balance.
I have a Magtag PAV2300. When it is in the spin cycle the tub goes off balance and has a knocking sound. What can I do about this. I have a 22 year old Maytag washing machine that has worked wonderfully well for 20 years. The last 2 years it has developed a knocking sound during the spin cycle and sometimes it will not spin at the full speed.
    Problem Solver:
  • 13 Answers
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Posted on Feb 05, 2009
Why won't my washer spin?
Sounds to me like your washer tub had a very unbalanced load in it (heavy blankets, jeans, or pillows, all piled to one side instead of evenly distributed around the inside of the tub), and it threw it off balance. When it began to wobble and knock, it may have broken the mechanics underneath the tub which make it spin. The only way to properly diagnose it is if you remove the outer casing of the washing machine and look beneath the tub for broken/out of place items.
Feb 07, 2016 | Bosch Washing Machines
Washing machine startee knocking loudly on spin cycles
this is usually an indication that your tub is off balance you need to stop the cycle let is come to a stand still and once it has stopped spinning then shift the clothes around to evenly distribute them. or remove some as it may be over filled and will not wash well if it is over filled. off balance can also mean over full so if it continues to knock then remove some items until it stops knocking
Jan 03, 2011 | Washing Machines
When it goes into the spin cycle it makes a loud knocking noise like a gear or belt is bad. what can i do, it is only 1 1/2 years old.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.If the bearing is getting out of its way then its faulty weak motor causing this.Check out both the bearing and the motor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
This may help. There is a plastic tab at the bottom back center of the washers (Mine is clear Plastic). This is designed to hold the Tub i n place when it is shipped. First try turning this 90 Degrees, until it is noticable loose. If that does not fix it, you can actully pull the plastic thing out with pliers, as it serves no purpose once the washer in place. I turned mine and the problem seemed to go away so I did not pull it out, but the guy at the store said I could pull it out if I wanted to.
Give that a try
Feb 01, 2009 | Maytag Performa PAV3200
Spin cycle noise
Most likely, your pulley is coming off, my pulley mad that knocking sound for a year before the belt fell off and I had to address it. see the previous post on how to fix this issue.
Oct 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Will not spin out heavy loads, stated by not balancing 2 mos ago
the transmission is shot after 20 loads a week for 4 and a half years
Oct 03, 2008 | Maytag PAV2300 Top Load Washer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
582 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
