Clean the inside and deposits
1) Copy following link for illustration of both gas and electric water heaters, and instructions for flushing water heater:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Before emptying tank, use weight of water to help remove and inspect anode rod. This will prolong life of water heater.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
3) Add a comment Feb 2013 and describe type of water heater and what you have done so far.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Turn off breaker to heater if it is electric, turn off gas if not. turn off water supply to heater. Hook up hose to bottom drain (if one is not all ready piped to outdoors). Open water drain valve at bottom then open any hot water side of the faucet. Tank should drain down, taking some of the buildup with it. Once drained, close faucet that was opened, turn water supply back on and flush out remaining deposits. It may be neccesary to replace the anode rod from the top of the heater if you have excessive build up.
