Question about Baby Lock Esante
Thread catches and clogs in gears near the uptake arm.
I have an Esante Ese2 and the top thread keeps breaking. When I remove the end cap the thread is all bunched up and tangled to the right of the uptake bar in some tiny rollers. I have tried everything I can think of to prevent this. Any suggestions?
  • 1 more comment
  • cchriste8463 Feb 05, 2009
    Would I have to take it to a dealer for that? I can't really get at the gears. Could it be something else?
    I have rethreaded numerous times. I have check and re-checked the threading procedure. I have changed thread, changed needles, changed bobbins and cleaned the bobbin case. It seems to sew fine for about 100-200 stitches then breaks. The top thread is all tangled in that little box (I don't know what to call it) near the uptake bar. I have to use tweezers to remove the tangled thread. I'm hoping I can fix it as, naturally, I have a project I want to finish and don't have time to take it to the shop. Thanks.
    I reset the tension to the auto mode. Should I manually adjust it and would that be higher or lower?
  • 848 Answers
1) Rethread the machine
2) Reduce the thread tension (lower number)
3) Select a larger size needle
4) Remove and reinsert a new needle, flat side toward the back of the machine.
Posted on Feb 05, 2009
  • 4,806 Answers
Hi there
You will need to adjust the tension and clear the thread from all the moving parts.
Thanks for using Fixya!!!
    Brigadier General:
  • 3,614 Answers
Check all of this;
  1. Correctly thread machine. Remove knot.
  2. Correct thread tension.
  3. Replace needle.
  4. Replace needle with correct size.
  5. Properly insert needle.
  6. Start machine at a medium speed.
  7. Use proper thread or needle.
  8. Check threading order.
  • micromaster
    micromaster Feb 05, 2009
    • Securely install bobbin into bobbin case.
    • Correctly thread bobbin case.
    • Check to see that bobbin has been wound evenly.
    • Clean bobbin case and shuttle.
    Just let me knw..
  • 250 Answers
The gears may be wornout or getting blocked in between.just check out.
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Sep 05, 2016 | Kenmore Sewing Machines
How do I fix a White sewing machine #445 that keeps breaking the upper thread
Check the thread spool to make certain the thread is not getting snagged on the edge of the spool (or the little slit where you pull out the thread from the spool); then check your tension paths and settings (I once found broken, tangled metallic thread in the needle 'uptake' loop that was snagging the thread and making it break).
Canned air is excellent for cleaning out older models as well as the new electronic machines.
Feb 03, 2015 | White Sewing Sewing Machines
My thread uptake lever keeps coming unthreaded. It causes stitches to be skipped and eventually the thread breaks. I have adjusted the tension, it doesn't help.
take up lever--try putting some tape on it to see if that will stop the thread from coming off.
also change the needle--make sure is the correct one for the fabric
Apr 14, 2012 | New Home Sewing Machines
Why does my Gutterman thread keep breaking on my 6600? I was told this was a good thread to use a Janome dealer?
Have you got the thread aerial up and using the thread cap on top of the spool of thread to ensure it feeds off smoothly. Also need to look at the thread spool, some of them have a little cut in the top where the thread end is placed to keep neat. If the thread is catching on this, just turn the spool up the other way and use the cap to hold thread away from the edge of the spool.
Gutterman is a good quality thread so you need to check that there isn't something in the thread path catching the thread and affecting the tension which is why it usually breaks. It could be a burr on the bobbin holder, the black plastic tensioning device which sits on a magnet. I have managed to damage 3 of these with my 6600P by trying to stitch too heavy weight seams, the bobbin holder moves and then the needle strikes it, once to the point of piercing right through it!
So have a look in the bobbin area, refer to your manual if you haven't removed the bobbin holder before. There is two little red marks that need to line up when it is in the right location. If you can see damage on the bobbin holder, you could take it out and try to file down the burring with a nail file or very fine grade sandpaper and then put back in again. The needle thread could be catching on a burr as it comes around during the stitch process.
Also, look at the top tension dial, turn it to zero and clean between the discs with the selvage edge of a clean piece of cotton waste. Then turn tension back to 5 and thread up everything and try again.
If you have tried all the above without success then perhaps take it back to the dealer and ask them to test sew it for you and see if they can spot the problem.
Apr 08, 2011 | Janome Memory Craft 9000 Computerized...
I have an Esante ESe2 and am having trouble with the upper thread breaking. I have checked bobbin case for fuzz and thread, re-wound the bobbin, re-threaded everything and nothing helps! Please help me...
Open the top part of the machine. My mom just bought one and it had lots of thread inthe thread path of the thread on top. You have to open up the area that the thread runs thru. It solved her problem of thread breaking. She found lots of thread inside.
Dec 16, 2010 | Baby Lock Esante
I have an Esante ESe2. I am having a problem with the bobbin. I was doing some embroidery and the machine broke a needle in some dense stitching. Now, the machine will sew about 10 stitches and then the...
Since the needle broke, it could have knocked your machine out of time--requiring service.
FIRST, try this: Remove the upper thread from the machine, ALWAYS RAISE the presser foot and rethread from the beginning. Frequently, when the thread "jumps" out of the thread path (or wraps around a guide or the spool), the thread will stitch about an inch and then break. If you watch the upper thread when you are stitching, do you see the thread tightening, tightening, tightening and then Snap?
As far as the bobbin installation, you would need to consult your owner's manual.
Apr 16, 2017 | Baby Lock Esante
Thread is catching & breaking somewhere inside the machine before it gets to the needle. brother XL-5600 machine
According to page 18 of the manual, the only place the thread could be catching would be the tension discs or the uptake lever.
Lift the presser foot and run a heavier thread or flat, unwaxed dental floss through the threading procedure to see if this will clean out a thread that may have jammed into the discs.
Always thread with the presser foot up and make sure the uptake lever catches the thread.
If this continues, take the machine to an authorized Brother dealer for service.
Apr 10, 2010 | Brother XL-5600 Mechanical Sewing Machine
How do I thread the machine
Raise the presser foot.
Place the thread spool on the spool pin so the thread feeds from the back of the spool.
Place spool cap against the thread spool.
Take the thread across to the first guide, then down the first slot, back up the next to catch the uptake lever, then down to the needle.
At the top of the needle there should be a metal "hook" that helps hold the thread close to the needle.
I found a download for the manual at this site for $5.00 -
Apr 02, 2010 | Singer Featherweight 132Q Mechanical...
Top thread keeps breaking on ESe2.
Many things can inter fear with the thread and cause it to break. A common problem is the thread getting wrapped around the top tension rollers on that machine. You can take off the "face cover" (side cover on the left) and look from the side and see if the 2 little rollers have thread wrapped around or underneath them. Start there.
Jun 27, 2009 | Baby Lock Esante
Thread is gettting caught in bobbin area of my esante ese2. HElp needed!!
It could be that your bobbin case popped out of position. Try removing and resetting it.
It could be that you have no upper tension, either lint in the tension discs or upper thread is mis-threaded and did not get down into the tension discs (make sure lifter lever is up when threading so the discs are open).
good luck!
Jan 31, 2009 | Baby Lock Esante
Sewing Machines Logo
43 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
