Question about RCA Televison & Video
TV power light comes on but no picture/no sound
Power switch will not turn TV off. Must unplug to shut off power light.
TV was playing with good picture and sound but began shutting off intermittently and now will not get picture or sound at all. I have RCA model; tv cuts on but no picture and no sound; cannot cut tv off with switch or remote; have to unplug to get power off; tried to reset but nothing helped
    Sergeant:
  • 359 Answers
Chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Posted on Feb 06, 2009
Tv will power on not picture
I would have the power supply checked for the screen and then have the power button checked it may be faulty.
Sep 20, 2017 | Panasonic WD65638 Mitsubishi WD65638 65""...
TV doesnt Come On
HI,
Can you please give the make and the model no.
Jun 07, 2008 | Televison & Video
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My polaroid TV will turn on but there is no picture or sound
blown caps in the power supply a 470m at 16 volt cap it will be puffed up
Sep 18, 2009 | Polaroid FLM-323B Television
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
Hi
check the main fuse that should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as soon as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply.......
Check horizontal output transistor.............
you have warranty go with it .......you can get it fixed ....
Feb 10, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Hdtv-dlp has no sound or picture
This sounds like an o-so familar problem. It sounds like the Switching IC or the MICOM has failed
Nov 10, 2006 | Samsung HLN467W 46" Rear Projection HDTV
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Mar 20, 2006 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
835 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
