Question about Microsoft Picture It! Publishing Platinum 2002 for PC
Picture it 10 Shaped Text Cannot be Inserted.
But Text can,it is not a low memory problem ?
  • 1 more comment
  • raybowers195 Feb 05, 2009
    I am running XP pro & Vista Home & have the same problem
    Yes, I have" no updates.
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    What OS are you running?
    President:
  • 1,902 Answers
Have you tried to see if there are any updates available for Picture it?
Posted on Feb 05, 2009
Kodak EX 1011 does not recongnize memory card
On the contrary. The EX1011 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and the frame will not recognize it as a memory card. You need to use SD cards, 2GB and smaller.
Jan 31, 2012 | Kodak EasyShare EX1011 Digital Picture...
Even after I put the memory card in, it still keeps asking for a card to be inserted.
This frame is only supported by:
SD, MMC, xD and CF cards.
Try w. dif. card. low gig and not highspeed hopefully it willl work.
If it does pls. rate me TXS
Nov 12, 2009 | Coby DP-772 Digital Picture Frame
AFTER 40 TEXTS IT NOW SAYS MEMORY LOW DELETE, I HAVE A MEMORY CARD. WHATS THE DEAL?
go into your opitons in the message screen and turn on auto erase and it will erase the read text messages when in reaches the full amount with out you having to manually delete them yourself and it will keep the picture messages you get
Oct 15, 2009 | LG enV3 VX9200 Cell Phone
Lg klp500 restarts when opening gallery with sd card inserted
Try to format the memory card first with the computer
Try another card
Look for the supported card for the phone
basically that means that the phone cannot really read the memory card or the card has a broken or corrupted file
Sep 25, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
My nokia N99i China mobile recently developed a memory card fault
I removed the memory card and inserted another one, I then removed the memory card and inserted the original one, it doesn't display memory card in the file manager. and when i'm taking a picture it says "restore etc. " in my restore factory has a password . i don't know what is the password . can u help me .
May 19, 2009 | Nokia Cell Phones
My LG AX300 freezes up, mostly when texting. How can I resolve this? Alltel won't help because I got it with a prepaid plan for my daughter.
Basically either as a result of low memory space for processing or currupt firmware. In the case of Memory space, you can improve the memory space by deleting unecessary files, applications, games and/or old text/picture messages to create processing memory spaces. Otherwise, have the phone flashed with a new firmware (save your contacts before applying this option)
Apr 10, 2009 | LG ALLTEL AX275 Cellular Phone
MOTORIZR Z3 - Message Memory Issue
One of my few complaints about my Z3 is the low message capacity. I have a 2gb sd card in there...why can't I store more than 500 texts?
But...500 is a lot more than 10, there's definitely a problem here.
I know there's a way to change the default storage location, although I'm not sure it will change the location of texts or not. Here's how to do it:
Go to the main menu and select "Settings". Scroll down to "Phone Status" and select it. Then select "Download Location" and finally, select the memory card.
Now...What concerns me the most is the 4Tb message flood O_o
Aug 27, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
Edit Text on a picture after Adding it
no, text in an image is not saved as text, it is encoded to each pixel that it overwrites.
do not add text in camera, save the images to a hard disk and use a simple image editor, like irfanview http://www.irfanview.com, to do the text overlays, it has undo, you can use irfanview to pixel edit the text set image
May 16, 2008 | Olympus FE-230 Digital Camera
Text memory
The memory used for messages is shared across many different areas on your mobile.
Your memory can be used by:
1. Address Book
2. Pictures
3. Music / movies
4. Games / Extra Applications.
If you have any of the above I would recommend you perform cleanup activities to limit how many you may have.
Apr 24, 2008 | Motorola Mobility RAZR V3
Wont accept xd picture card
Hi, tecnil
Device cannot detect files on the memory card.
Cause
The memory card might be missing or inserted incorrectly. Verify that the memory card is inserted correctly.
The files might not be in the correct format. To print from the device control panel, the files must be in the sRGB JPEG format. To print other formats, you must use a software program on your computer.
You might have inserted more than one memory card. Only one card slot can be occupied for the device to detect JPEG files. Verify that only one card is inserted.
oke,
thx
cropp
Jan 08, 2008 | HP Photosmart 7450 InkJet Printer
Microsoft Picture It! Publishing Platinum 2002 for PC Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
