Lutron Dimmer Not Dimming But On/Off Works
Hello -
I recently had a dimmer installed in my kitchen. It's lighting a Lightolier track system with 4 50-watt fixtures on it. The dimmer was working fine for a month - until yesterday.
The light turns on/off without any problem, but the dimmer does not work. Does anyone have any ideas why the on/off would work but the dimmer doesn't?
I have other Lutron dimmers in the apartment and haven't had any problems with those.
  • geoffcardill Feb 14, 2009
    I thought that I'd bought a dimmer with a high enough capacity. But I'll have to re-visit that.
    I have the same dimmer on a track that ALSO has 4 50-watt lights and I've had no problem with that one (yet).
  • 227 Answers
What is the dimmer rated for? Your load on the track appears to be 200 watts. A standard dimmer will burn out, you need to look on the dimmer to see what it is rated for. Did it run hot with the dimmer before you had this problem? They make dimmers for higher wattage that will do the job for you.
Posted on Feb 09, 2009
  • 66 Answers
The type of track heads you are using could be creating the problem. Are the lamps Par 20, Par 30 (screw in base) or MR-16 low voltage (push in base)? If the track head has a small (2"x4") box and uses MR-16 lamps then you need to use a dimmer specifically designed for ELECTRONIC LOW VOLTAGE. Incandescent lights (screw in base) and Electronic low voltage need a different signal to dim. Using a standard dimmer for electronic low voltage will work for a while, but then either the dimmer or the fixtures will go bad. If your lamps are incandescent or halogen you may have just had a bad dimmer. (Not common for Lutron products) but the part number you list should be good for 1000watts and should not be the issue.
Please see "Dimming Basics" under the helpful information tab for a better explanations of the two different styles of dimming. Hope this helps!
Posted on Oct 09, 2009
4 Suggested Answers
  • 15 Answers
SOURCE: Dimmer switch is not dimming
florecent bulbs wont dim unless they are dimmable.
Posted on Dec 25, 2008
  • 1605 Answers
SOURCE: 3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
Posted on Mar 30, 2009
  • 704 Answers
The Lutron Maestro dimmer isn't rated or designed to operate low voltage lighting as it is a 120 V-AC rated electronic dimmer. You should either install a standard low voltage ON/OFF switch on this installation or obtain a dimmer rated for use on low voltage lights.
You need special low voltage dimmer designed for use on the low voltage pucks lights you have installed. Usually the low voltage is either 12, 24, or 36 volts, depending on the manufacturer of your particular light set. Once the correct dimmer is in place, the problem with the flickering and pulsing of the lights, should cease.
If you still are having this problem and you can't find a low voltage dimmer, you can contact the maker of your low voltage light kit and they can provide you with an acceptable dimmer option for your lights.
Most Home Depot and Lowe's carry the low voltage puck light kits, and usually have accessories for these lights, including dimmer switches that will work with them.
Hope you find this Very Helpful and best regards!
PS: I found this old, unanswered question and wanted to provide a solution to close out the problem and clear the question from the site.
Posted on Sep 10, 2009
I recently installed a lutron skylark dimmer w compatible gu24 bulbs on a 3 way connection. Everything works properly but the bulbs only dim slightly, is this normal or is something defective or improperly...
Are you using compact fluorescent? Are you sure you purchased a dimmer that is for incondescent lighting only? fluorescent lighting only? Fan motor control only? Are your lights led? I read on the instructions for one company that you can only use one dimmer on any one 3 way system. Did you put 2 dimmers on a 3 way system?
Aug 11, 2013 | Electrical Supplies
I am replacing a Lightolier 3-way Dimmer switch with a Leviton IPI06-1LX Dimmer switch. When I install the dimmer switch it works fine. But the on/off regular wall switch won't turn the light on or...
It depends. Some dimmers are considered "smart dimmers," where the control on the other end of the 3-way has to be intelligent enough to send a signal back to the dimmer. If the Lightolier dimmer was a smart dimmer, then chances are that the 3-way control was designed to talk only to that specific dimmer. The Leviton product you replaced it with is a simple, basic dimmer - it should work in conjunction with a simple, basic 3-way switch.
If the 3-way control already IS a simple, basic 3-way switch - then I would simply re-check the wiring of the dimmer you replaced.
Sep 11, 2011 | Electrical Supplies
Hi I've got a Lutron electronic slide dimmer
Let's start whittling away some of the information...
First of all, the ZP260QE is from Lightolier,so you may want to give their tech support center a call.
Secondly, ignore the continuity tests, they tell you nothing. Continuity on the secondary is expected because you're on the output of a "true" transformer, which will look like a short on a DC-supplied continuity test. The input to an ELECTRONIC transformers is a switching power supply, which will not look like anything when supplied by a DC voltage/current during a continuity test. Those test results appear normal to me. The +/- 60 also makes sense, if you've measuring voltages on the output of a dimmer, the impedance of the dimmer's off-state and the impedence of the multi-meter makes for some screwy readings that don't always make sense.
Most dimmers rated for electronic low-voltage have protection circuitry built within them to make sure they're not overloaded. Normal incandescent dimmers will just get warmer than usual, these guys should shut down - perhaps that's what you're seeing.
My two suspiciions are either (a) the additional pendent light, combined with the existing track lights, tripped the overload protection, or (b) when you added the pendent light, you got too much of a current inrush that shorted out the components within the dimmer.
Jun 04, 2011 | Lutron Electronic Low-Voltage Dimmer...
What Dimmer can I use That looks like an OS600 but is for a GU24 Dimmable CFL
Depending on your wiring, as to single pole (one switch location) or 3 way (two switch locations) you can use most dimmers. Leviton and Lutron have similar dimmers, and some specifically for cfl's.
Leviton has Sureslide, Illumitech, True Touch
Lutron has Diva, Skylark, and Lumea
Make sure your cfl is dimmable.
Mar 03, 2011 | Philips Lightolier Onset 600W Incandescent...
We have an older maestro style lutron dimmer switch with a horizontal slide button at the bottom that can turn it on and off. we are using this button to operate the light b/c the vertical...
These in-wall devices stop working and need to be replaced from time to time.
There are no repair parts.
Generally dimmers don't last as long as ordinary light switch, because they are electronic instead of mechanical.
Lutron makes the widest selection of dimmers.
Use link above to identify dimmer.
For example Skylark dimmer.
Then google search for a replacement.
For example: single pole 600 watt lutron skylark dimmer
Or: 3-way 600 watt skylark dimmer
Lutron also makes 1800 watt dimmers for larger loads.
Add a comment any time if you need more help.
You can also take advantage of fixya phone service.
Fixya expert will talk with you via phone for a price.
Dec 24, 2010 | Lutron Electrical Supplies
The on-off switch for the dimmer is "loose" and does not turn the light on anymore.
There are no repair parts for in-wall electrical devices.
When they go dad you buy another.
Lowes and Home Depot carry inexpensive dimmers.
Look for 3 things:
1) Wattage: most off-the-shelf dimmers are 500-1000Watts. Add up total wattage.
2) If you are dimming incandescent bulbs, dimmer package will say tungsten or incandescent.
Package will say florescent if dimmer also works for florescent bulbs.
3) If dimmer is 3-way, with a dimmer on either end of a room, many times the dimmers are sold as a package of 2 dimmers with 1 dimmer that controls the other dimmer.
Lutron dimmers
Leviton dimmers
Nov 15, 2010 | Lutron #DVW-603PGH-WH 600W White Single...
Audio system buzz with dimmer-controlled track
It may be too late given the date of this post, but the buzzing has nothing to do with the bulbs (usually, dimmers and lamp buzzing are a common problem which is why you probably got the suggestion), but in your case, you have radio-frequency interference from the dimming circuit leaking into the audio circuit. The best things you can do is either minimize the RFI, or separate the audio circuit away from the dimming circuit. Based on what you're saying about the PC input, it sounds like the main culprit is that specific audio wire going between the PC and the sound system - can it be run differently so that its further away from the dimmer/circuit. Are the PC and the dimmer on the same breaker? - If so, maybe noise is radiating from the dimmer into the PC through the power wiring - putting on different breakers could help.
One more note, the best dimmers, in terms of RFI performance, are reverse-phase control dimmers (usually designed for electronic-low-voltage... and be careful because they often get confused with magnetic low-voltage... and those will not help. Without going into too many specifics, the ELV dimmers have a much softer on/off/on/off dimming cycle when compared to standard incandescent dimmers (this is a circuitry thing with a much more complicated explanation), but as a result, they tend to have significantly fewer issues with RFI. They can be an expensive solution for simple problem solving, but the MIRELV-600 should do the trick (again, don't be fooled, the MIRLV-600 is the magnetic low-voltage product, and for what you're doing, won't help).
Feb 07, 2010 | Lutron MIR-600 Remote Control
Dec 24, 2008 | Lutron ELECTRONICS CO. Q-603PH-WH "QUOTO"...
4,030 people viewed this question
Top Lutron Electrical Supplies Experts
Craig Butler
Craig Butler
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
