Question about Whirlpool GU2400XTP Built-in Dishwasher
NOT DRAINING AND WATER ON FLOOR
I HAVE THE WHIRLPOOL QUIET GOLD GU940SCB AND ALL THE WATER IS NOT DRAINING OUT THERE IS STILL ALOT LEFT OVER. JUST LAST NITE THE WATER STARTED COMING OUT ON THE FLOOR.
  • lynnann8390 Feb 16, 2009
    THANKS FRED FOR YOUR FEEDBACK NOW WHERE WOULD THAT PIPE BE LOCATED ? IS IT UNDER THE DISHWASHER? I LOOKED UNDER THERE AND SAW HOSES BUT WHICH ONE AM IS SUPPOSED TO TAKE A LOOSE?
  • 3 Answers
Hi ya,there is a blockage in your waste pipe take it off and clean it out i had the same prob about 2 months ago
Posted on Feb 05, 2009
Whirlpool quiet partner II stops running or won't complete it's was cycle, sometimes is will wash for a few minutes and stop or it will stop before the water even starts to flow.
I had the same problem with my dishwasher. After hearing that the motherboard was the problem I decided to take a closer look. There were two capacitors (1000 microfarads, 6.3 volts) that looked a little suspect. The tops of capacitors should be flat...these looked like soda cans that had been left in the freezer. Got on eBay, located the capacitors for roughly $3 and $4 shipping, for approx total of $10. Soldered the two new capacitors into the motherboard and put it back together. As soon as I closed the door, the dishwasher started draining the water. When I ran a Normal cycle it completed successfully. Saved myself over $120!
Aug 02, 2013 | Whirlpool Gold Dishwasher with Quiet...
Over flows water on to the floor when operating
as the question states, the floor drain overflows a little (but enough to be annoying) when water is run any where in the house. I rented a motorized snake machine and did that, pulled up some stuff but didn't fix the problem. We have had a ton of snow lately and it is starting to melt. Could this be part of the problem or do I need to call the plumber? Thanks in advance.
Apr 03, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
We have a Whirlpool Gold Quiet Partner GU980SCGZ0 model. When rinse cycle is over the water only trickles out when draining. We checked the drain and it is not plugged. Water remains sitting in bottom of...
I took the check valve assembly off the bottom of the pump assembly and there was a big chunk of string balled up in the line which created a plug against the screen when trying to drain.Works great now!
Feb 15, 2010 | Whirlpool Dishwashers
My whirlpool gold side by side refrigerator forms a big peice of ice at the very bottom then the ice ends up melting and goes all over the floor whats wrong?
the drain in the back of freezer is blocked
dismantle front of evaporator and deice drain
maybe so hot water over this should fix problem
whendrain is clear water should run donwn hole and collect in evaporator tray under fridge
you may need to mop up after you finish
Nov 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Seem like its not draining. soapy water when finished cycle.
found a kink in the drain hose, shortened hose-problem solved.
Mar 22, 2009 | Dishwashers
Water remains in Whirpool Gold Quiet Partner dishwasher
sounds like an issue with the drain pump, disconnecting the drain hose fromm the trap and run the unit, pointing the disconnected drain hose into a bucket. You should get a fairly strong stream of water until most of the unit has drained, if not you either have a blockage or ,with the grinding sound, a bad pump.
Mar 11, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Feb 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold quiet partner 3 wont drain.
The new garbage disposer comes with a plastic cap in the drain port. Disassemble the drain pipe assembly and remove the cap/plug.
Jan 13, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GU2400XTP Built-in Dishwasher Logo
128 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
