Question about Galaxy Radios DX-95T Base CB Radio
Tparsenault galaxy 95 t echo off, roger beep off, talkback off, 8 foot steel whip, 18 ft gray coax, rk 56 mic, it is not really a squeal as much wine when you key up and talk a little while with the engine off, and if yuo talk a lot with the engine on it will still do some(not a lot) it is in a 93 gmc z71, standard battery and 3rd alt.
  • 170 Answers
OK I remember a similar problem with a connex radio. It seems the driver's fm radio speakers where picking up some signal even with the fm radio off. Shortening the speaker wires helped some, also make sure you don't have any wire or coax coiled up anywhere. Thats about all I remember, hope this helps.
Tp
Posted on Feb 09, 2009
I have a galaxy dx 99v2 18 ft coax hooked directly to ball on my 102 wip and spring ,3ft jumper to swr meater all grounded to battery and power directly to battery tryed to set SWR and pegeing out
first of you have to set the SWR on the radio first . then some liniers require you to run low wattage and others high wattage . the SWR is what you have to control by keeping it low . You must take into consideration the length of the coax plus any jumpers you have . You say you have 18 ft of coax plus a 3 ft. jumper ,thats 21 ft..You should keep that jumper as short as possible ,like 12" . plus you should make sure the antenna is grounded good , like to a good spot under the vehicle . 102 " whips are supposed to be almost perfectly tuned for a good match .
Apr 07, 2015 | Radio Communications
How do i set my galaxy dx 88 hl so the talkback is on all the time
turn the talkback knob to the right and push it in to engage talkback.when you get the volume you want leave it alone .Now key the mic.You will probably hear a squeal coming from the speaker.Now turn the volume down on the talkback knob until the squeal goes away.If you run your RF gain wide open it may squeal also.
Sep 25, 2013 | Galaxy Radios DX- 88HL Base CB Radio
My radio squeals with echo when my amps on
adjust your talkback to just open then set your echo to where you want it. Now turn your amp on and re-adjust both the talkback and the echo . If you have a speaker nearby the radio may be feeding back through it so move it away from your radio . Now start talking with the mic and adjust your echo because you should be able to hear yourself talk through your talkback.
Dec 21, 2012 | Galaxy Radios DX-959 40-Channels Base CB...
I have a Connex 4600 Turbo mounted in the headliner of a W900L Kenworth using Wilson 2000 twin antennas and a RK56 mic. When trying to use the "talk-back" feature all I hear is constant...
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Nov 08, 2010 | Connex 4600 Base CB Radio
I have a uniden grant and i have wired a galaxy power desk mic with rogger beep when ever i key it up it squeals was wondering is there a way to fix that
yeah your mic gain is way too high. You can either turn off talk back if you can, or turn the gain down. Depending on how loud the talk back is, your audio may suffer. If that is the case, you will not be able to run that mic. Get an RK-56 or a Skythumper mic. They are noise canceling. You will get no squeal with that mic, and it will sound awesome.
If you really want a roger beep, take it to a tech and them install one.
Oct 23, 2010 | Galaxy Radios DX-66V Base CB Radio
I have a dx98vhp and it sqeels* when i key up when the talkback is on. I've tried adjusting the power and i can't figure it out. Thanks
the talkback is too loud. there is no way to adjust the talkback volume on this radio. Talkback is really just so you can check how your audio sounds and your echo. Once it set, there is really no need to have it on.
Turning down the gain on your mic will stop the squeal.
the squeal is cause by feed back from audio from the talk back being heard from the mic.
Sep 14, 2010 | Galaxy Radios Microsystems DX98VHP CB...
Coax length
the shorter the better between radio and linear, all coax has to run in 3 ft, 18 foot is recommended for all antennas.
Mar 03, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
Galaxt 95t when i key the mic i get a squealing noise
Maybe check to see if the talkback is turned on.If so, turn it ouff you mght be getting feedback because the mic is too close to radio. Try external speaker, or a nise canceling mic (rk56,or astetic 623),
Also this is a realitive high power radio, so make sure you have a good match on the antenna and you arent starving the radio for power.
Wish you where more specific about the sqeal if it was feedback or echo was acting up. Alos built in roger beet makes tehe short squueal when unkeying mic.
Feb 03, 2009 | Galaxy Radios DX-95T Base CB Radio
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Galaxy Radios DX-95T Base CB Radio Logo
110 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
