Question about Samsung SyncMaster 753 DFX 17" CRT Monitor
Pincushion and Horital Size Problems
Samsung sync master 753 DFX 17" crt monitor pincushion and horizontal size cannot adjusted
  • Dolar Mar 25, 2009
    I am trying to adjust the Pincushion and Horital size but its not working. And all other adjustment is working. Now please advise me how to solve it. Is this the problem of Monitor or thr Graphics card.
    Thanks
    Contact:
    mmh.dolar@yahoo.com
  • 38 Answers
This is a hardware based issue, and sadly cannot be fixed without sending it to a service center. If you really want to, you can send this monitor to a service center, but it will be around 100 bucks to fix. I would say just replace it with a smaller LCD panel. They can be bought for around the same price, and they'll save power too.
Posted on Feb 05, 2009
  • Eddie Guarraro Feb 05, 2009
    Fine, be that way. It's true though, so be a moron and rate it inappropriate.
I have a samsung 14'' color monitor model no samtron40n & found pincusion problem. please send me solution
Most CRT monitors have buttons on the front of the monitor select a menu to adjust various settings such as the trapezoidal, pincushion, vertical and horizontal height size and position, brightness and contrast etc.
Apr 01, 2010 | Computers & Internet
My Dell E773c Monitor's image is like a "hyperbola" wider at the top and bottom and narrower in the middle. The Horizontal adjustments do not do anything to correct the problem, Help!!!!
Try to do a factory reset (look up "recall" in the manual, or here: http://support.dell.com/support/edocs/monitors/e773c/EN/ug/setup.htm).
If this does not help, you need to adjust the geometry settings (H/V position, H/V size, rotation, trapezoid, parallelogram, pincushion and pin balance) using the monitor's settings menu. Expect a long afternoon of fiddling around until you get a satisfactory result. A test picture for geometry settings could be of help.
Make sure your computers video setting does not exceed the monitors specification of 1152 x 864 @ 75 Hz.
Feb 04, 2010 | Dell E773C 17" CRT Monitor
Pincushion and h size problem on aoc 17" 771s
one of the buttons on your monitor is partially shorted. trust me, ive encountered this problem many times.
Jan 03, 2009 | AOC CT720G 17" CRT Monitor
ViewSonic E70f 17" CRT pincushion changed itsself continously
Press the [1] key & hold it for 10 seconds / till OSD Unlock appears on the screen. When OSD unlock appears on the screen , release [1 ] & press [1] or [2] key. This will unlock the OSD.
May 22, 2008 | ViewSonic E70f 17" CRT Monitor
Lock/Unlock Display
Replace the 5v regulator 78L05 by a new one
Mar 31, 2008 | Samsung SyncMaster 753 DFX 17" CRT Monitor
Wide Screen Problem (Pincushion)
Some countries get themselves 'burned' to a spot because of lack of use. a slight twich one way or another will reset it . The control that you are referring to is it a direct acting one - that is does the work or is it of the switch variety- that is you activate the control but then have to move larger wheel to do the work?
May 28, 2007 | Samsung SyncMaster 793DF (Silver, Black)...
Can't Fix Pincushion
If the menu is appearing then it should be able to adjust the Monitor, provided you have replaced the micro switches. Check for continuity by pressing the buttons. I don't think that there is any prolem with other components.
May 05, 2007 | Samsung SyncMaster 793DF (Silver, Black)...
Dell monitor E773C 17"
It sounds like this needs component-level troubleshooting, probably in the signal section. It might also be loose connections or residue of some kind in one of the switches or on the switch board.
Jan 04, 2007 | Dell E773C 17" CRT Monitor
Samsung SyncMaster 753 DFX 17" CRT Monitor Logo
371 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
