How to change the drain valve washer in a waterheater
1) Copy following link:
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html#repair
2) You may find it is easier to put garden hose cap over dripping drain valve.
Screw very tight with channel locks.
3) Add comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: I have water leaking from the bottom of my waterheater PE50T9A
Turn off the electric and drain the tank. Completely remove the exit valve that is leaking and clean up the threads on the valve and in the hole. Get some plumbers dope and dope up the fitting threads and the threads in the hole and then reattach the exit valve. As a real precaution you may consider taking the plastic valve to the hardware store and getting a replacement one. Also dope that one up good.
SOURCE: leaking hot waterheater relief valve
you can try opening it into a bucket most of them are threaded to hook a hose to it. opening it and closing it might fix the leak but if not just turn the power and water coming in and take a wrench and turn the old one out. and get a new one at your local hardware store or home supply store like a do it best store or lowes or home depot.
Clogged cold water nipple or clogged hot water nipple.
Is water hot at drain valve?
http://waterheatertimer.org/Low-hot-water-pressure.html
