Question about Panasonic Panafax UF-780 Plain Paper Laser Fax
Printing fax verification
How can I print fax verification from the previous month?
    Genius:
  • 2,120 Answers
You can only print a JOURNAL for the last 50 transactions. Function 61 set
Posted on Feb 06, 2009
Fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Mike
Nov 14, 2007 | Brother MFC 8300 Laser Printer
Loud clicking noise on my hp printer 4500
hi, your priner complaint i 2 chance 1 is the carrage cable is damaged or 2 is printer mechanism complaint please verifing
Mar 26, 2014 | HP Officejet 4500 All-in-One -...
Is is possible to go back two weeks to see a journal report on my brother mfc 9440 cn series? I didn't save a confirmation page and I need to see confirmation of a fax sent two weeks ago. Thanks
  1. Press the Menu key.
  2. Press the Up or Down Arrow key to select Fax and press OK.
  3. Press the Up or Down Arrow key to select Report Setting and press OK.
  4. Press the Up or Down Arrow key to select Transmission or XMIT Report and press OK.
  5. Press the Up or Down Arrow key to select the option you prefer.
    • Off
      Transmission verification report will print only if a fax transmission is unsuccessful.
    • Off+Image
      Transmission verification report will print only if a fax transmission is unsuccessful with a portion of the fax's first page printed on the report.
    • On
      Transmission verification report will print after every fax transmission.
    • On+Image
      Transmission verification report will print after every fax transmission with a portion of the fax's first page printed on the report.
  6. Press OK.
  7. Press Stop/Exit.
May 10, 2011 | Office Equipment & Supplies
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
Press Menu/Set, 2, 4, 1.
-OR-
Press Menu/Set, 2, 4, 2.
You can use the Transmission Report as
proof that you sent a fax. This report lists the
time and date of transmission and whether
the transmission was successful (OK). If you
select On or On+Image, the report will print
for every fax you send.
If you send a lot of faxes to the same place,
you may need more than the job numbers to
know which faxes you must send again.
Selecting On+Image or Off+Image will print
a section of the fax's first page on the report
to help you remember.
Note
When the Verification Report is turned Off or
Off+Image, the Report will only print if there
is a transmission error, with ERROR in the
RESULT column.
1 Press Menu/Set, 2, 4, 1.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
Need fax confirmation report .
1) Press <Menu>
2) Press Up or Down <Arrow key> to select "Fax"
3) Press <OK>
4) Press Up or Down <Arrow key> to select "Report Setting"
5) Press <OK>
6) Press Up or Down <Arrow key> to select "Transmission" or "XMIT Report"
7) Press <OK>
8) Press Up or Down <Arrow key> until the option you prefer appears:
  • OFF - Transmission verification report will print only if a fax is unsuccessful
  • OFF+IMAGE - Transmission verification report will print if a fax is unsuccessful with a portion of the fax first page
  • ON - Transmission verification report will print after every fax transmission
  • ON+IMAGE - Transmission verification report will print after every fax transmission with a portion of the fax first page
9) Press <OK>
10) Press <Stop/Exit>
I hope this helps!
Jan 15, 2010 | Brother Multi-Function Center MFC-240C...
Every time i hook up the kodak esp9 to the computer it keeps spitting out copies of a picture i made a month ago
The problem with this is that the previous printing jobs are still on queue
To delete the Printing queue try doing the ff:
Double click the Printer Icon under Printers and Faxes then
Delete all the printing queue
Click Start then Run then type print stop spooler
Click Start then Run then type print start spooler
Try hooking the printer again
Hope this will help
Regards
Byron
Aug 21, 2009 | Kodak Office Equipment & Supplies
Can't find info - comfirmation
Its called "Transmission Verification Report"
Press Menu, 2, 4, 1
Select ON or On+Image
This will come with every fax you send.
If you want to customize, see owners manual under, "Printing Reports"
Oct 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Not printing faxes
It appears you have a faulty connection. Make sure the line is connected properly, also check to see if you have your settings set to Fax/Fax Receive mode.
May 27, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Avoid printing Transmission Verification Report
You have to change the fax menu settings. Here you can compute the machine to avoid the error reports (see manual chap. fax settings)
Jan 07, 2008 | Brother MFC 420CN All-In-One InkJet...
Panasonic Panafax UF-780 Plain Paper Laser Fax Logo
50 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
