Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Maxtor drive can not be detected from computer
I have this drive that i havent use for a long time. when i plugged it in for the first time the computer recognizes it but then when i go to my computer the drive was not there.
  • Natsley Mar 03, 2009
    I have the same problem, maxtor drive cannot be detected from my computer. Also, I haven't used it for a long time - and it ticks!
  • was_a_guru Mar 14, 2009
    Bought a One Touch III Turbo (2TB), configured it as RAID 1. Ran one backup. Two days later tried to run another backup. Drive was not detected by system. Re-installed drivers, drive was detected. Ran backup. In middle of backup got error message "Delayed Write Failed..., Operation Terminated". Drive was making clicking noise. Powered everything off then on again. Drive not recognized, and making clicking noise.
    I was in the drive business for 30 years, and this is an indication of drive failure. Didn't want to return drive as there was sensitive data on it from first backup. Took it apart and tested each drive. Sure enough one of the drives exhibited the clicking problem. It was toast!
    Lot's of similar posts on web. Apparently this is a common failure with Maxtor/Seagate drives. There is a law firm that is soliciting information from users that have had this problem for a class action lawsuit. See the URL below:
    http://www.kbklawfirm.com/seagate/what-i...
    Lessons:
    1. Don't buy Maxtor/Seagate drives
    2. Back up using encryption so if you have to return you can do so safely
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 138 Answers
You have lost the drivers for it. Go to Maxtor's web site and search for the drivers download for the model you have then install them.
Posted on Mar 13, 2009
  • Phillip Whisenant
    Phillip Whisenant Oct 15, 2009
    I have a Maxtor as well. Great external HD. You must go to www.maxtor.com and run new updated drivers for it. You said it has not been used in a while right? Then you deffently need to update it's drivers.
Does not recognize dvd drive
When you click Start/My Computer is the DvD drive shown as one of your devices? If not then try the steps below:
Remove the Power Cord, Remove the Battery, turn the laptop over and remove the one screw that secures the dvd drive and pull the drive out. After 20 seconds plug the DvD drive back in, and then try booting to see if it is recognized. If the drive is not recognized then you will have to remove upper and lower filters.
If you are talking about the drive won't play a dvd then that's another issue. Most times computers have a hard time playing something that was created by someone else. Try a store purchased DvD and see if it recognizes and plays it.
Apr 07, 2012 | Computers & Internet
Computer will not recognize wd1600c032
open up the case and pull the driver out. put the jumper to SL (slave) and plug it directly into *********** boards ribon cable after your windows drive (XP), if it does not recognize it try moving the jumper to the CL (cable select) see then, remember to turn off your computer before doing this each time. if either computer still does not see the drive the drive is probably bad. they dont last a long time if you leave it turned on and running all the time. they tend to get hot and burn out. if the drive it self is SATA you will need an adaptor, if its IDE (wide ribbon cable) it should plug in and be seen. hope this helps.
May 08, 2010 | Western Digital My Book Essential Edition...
Toshiba 60GB USB 2.0. Portable not recognized in my computer
Check you have the usb 2.0 drivers installed on the computer. You can check this in device manager in the properties of my computer icon. if you havent got USB2 enhanced host controller you havent got the driver.
You can find the Drivers and how to load them at this site:
www.softwarepatch.com/tips/usb2-driver.html
Jan 22, 2010 | Toshiba 120GB USB 2.0 Portable External...
Can not find mass storage on my computer
It need a software if you have already got than its ok if not kindly inform me my add is mh_ussa@yahoo.com
Feb 05, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Continuation!!!problem
As strange as it may seem, i have seen USB devices work one time and then be dead the next time you plug it in. I would try to connect it to another computer Or another USB plug on your current computer. If that doesn't work, You might try removing the driver for this device (if it has a driver for your MP3 player) and reinstall it. If when you connected it the first time the computer did not ask you to install a driver then the operating system already has the driver installed for your device.
Good Luck!
Jan 06, 2009 | Computers & Internet
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Problem starting up Maxtor 160 gb external hard drive
hi dutchgirlie,it doent matter if its a trekstor,but my 1st question is did u every try work the usb device?just to make sure it is working.if u havent make sure your usb device is enable in your bios.hope u knw how to do that.hope your harddisk shows up when you boot next time.have a nice time.
raj
May 10, 2008 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
408 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
