Question about OKI C5150n Led Printer
Oki Data C5150 Alignment
My OKI is printing really off and I think it is the alignment. When I print a document there is like a shadow effect going on that is not on the document to be printed. The only documents this does not happen on are black and white word/excel docs, but if I toss a colored word in that document it doesn't print straight (like it will be higher or lower than the black text) but in that case there is no shadow, just not straight lines.
I was told aligning the printer might fix this problem but I have no clue how to go about that. Any help?
(ps I am not sure if this is an led or what....I am completely clueless on most of this stuff)
5 Suggested Answers
flopez
  • 161 Answers
SOURCE: Oki C5150N Grinding noise
One of the drum cartridges is stuck. Test by removing them one at a time with the printer off, then turning on.
Posted on Nov 02, 2007
  • 139 Answers
SOURCE: Oki Microline 320 Turbo page alignment
This sounds like a problem in the computer program that is sending the prints to the printers....especially since it is happening in several of them.
Posted on Jan 23, 2008
  • 97 Answers
SOURCE: Oki C5150 printer menu is part english part spanish
How To:
Uninstall a Spanish or Portuguese driver and install the English version when Windows XP installs the incorrect language, where either a couple of the tabs are in the wrong language, or everything is incorrect.
Action:
IMPORTANT NOTE: THE PRINTER MUST BE TURNED OFF DURING THIS PROCEDURE OTHERWISE WINDOWS WILL AUTOMATICALLY INSTALL THE SPANISH OR PORTUGUESE DRIVER AGAIN. DO NOT USE PLUG 'N PLAY FOR DRIVER INSTALLATION.
1. Delete the Driver Icon from the Printers and Faxes Window.
IMPORTANT STEP:
2. Reboot the PC
3. Click on File --> Print Server Properties
0.2c6?openelement&fieldelemformat=gif
5. Click on the Drivers Tab.
6. Highlight the driver being deleted (C5200n shown as a reference below), and click on Remove.
0.347e?openelement&fieldelemformat=gif
IMPORTANT STEP:
7. Reboot the PC
8. Go back into the Server Properties Drivers Tab (as shown above), and click on the Add... button.
9. On the first screen click on Next.
10. On the Printer Driver Selection Screen, click on Have Disk.
4.7ce?openelement&fieldelemformat=gif
11. Browse to the location of the English driver that is to be installed and click on OK (Note, the C5200n printer is being used as a reference and the driver being installed is from the CD).
7.3852?openelement&fieldelemformat=gif
12. On the next screen the printer being installed should be highlighted, and click on Next.
9.628?openelement&fieldelemformat=gif
13. The next window Will show the version of the driver being installed, DO NOT click on any of the unchecked boxes and just click on Next.
12.6e6?openelement&fieldelemformat=gif
14. Click Finish on the last window.
15. Finally, turn on the printer. Windows XP will automatically find the printer and install the English version of the driver.
Posted on Dec 08, 2008
Soulvisitor
  • 1113 Answers
SOURCE: OKI C5100 alignment issues, I think
FROM YOUR USEWR MANUAL>>>>>>>
In colour menu
AJUST REGISTRATION, press EXECUTE
Performs automatic colour registration
adjustment. Normally this is done on power
on and when the top cover is opened and
then closed. This process accurately aligns
the cyan, magenta and yellow images to the
black image.
Use oki drums and toners, clean led heads
Posted on Dec 20, 2008
SOURCE: oki c5150 wont print black
First, clean the LED heads with a lint free cloth and isopropyl alcohol (the LED heads are the attachments on the underside of the lid when you open your printer; four of them for each color). Try printing something after doing that. If it's still an issue just with black, try switching the black and magenta drums/toner (keeping them locked together). The drum w/ toner cartridge simply pulls straight up and out, no switches or locks to flip. Then print a page of text; which will output from the printer in magenta. If that looks okay, then it may be an issue with your black drum and needs to be replaced.
Posted on Jan 13, 2009
Oki c5200 alignment
often a drum unit will go bad causing misalignment of just one color. print the demo page and that will help you diagnose what one of the 4 colors is off and replace only that one drum unit
Jul 01, 2014 | OKI C5200 Color Laser Printer
C5150: All color prints are extremely streaky and
This happened to me. It was caused by a bad "oki compatable" color cartridge. One time it ruined my drum. It was always the yellow color. Decide which cartridge is printing streaky. Remove it, bang it on the inside of a large plastic garbage can. Clean it. Reinstall it . If it still prints streaky throw it befor you ruin the drum. Replace it.
Nov 07, 2009 | OKI C5150n Led Printer
In colour menu
black image.
Dec 19, 2008 | OKI C5100n Laser Printer
My semi-educated guess would be that your transfer belt unit is getting close to the end of it's time - This is Part No. 351002.
Jul 24, 2008 | OKI C5100n Laser Printer
Oki Microline 520 printing slow
Your printhead alignment is out thats why it prints slow
Jul 17, 2008 | OKI MICROLINE 520 Matrix Printer
Printing trouble
I think your alignment is out you need to get the printer serviced and aligned.
Dezzi
Apr 10, 2008 | OKI MICROLINE 521 Matrix Printer
PRINTS NOT ON DEMAND
The types of printers that you have actually should be assigned to a free port, you cant setup 2 printers on the same port. check at the back of the printer the physical attachment of two printers the OKI and the Epson, if Oki is set to lpt1 then assign port from printer properties for oki to lpt1, and lpt2 on epson. 1 printer- 1 port, so by then check if the box for enable bidirectional support is check, remove the check mark from the box by clicking on it then hit apply then try printing a test page then try printing from application.
Apr 08, 2008 | Epson TM U325PD Matrix Label Printer
Jan 23, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing in one direction only
Your printers alignment is out that is why it prints only in one direction.
Dezzi
Oct 11, 2007 | OKI MICROLINE 521 Matrix Printer
Printing darker
charging connections are not properly connected
Sep 06, 2007 | OKI C5150n Led Printer
OKI C5150n Led Printer Logo
96 people viewed this question
Top OKI Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
