Wont print
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing.
thanks
SOURCE: Hi I have a Brother DCP 130 MFC I have an error
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
All the Best Pineworks
SOURCE: My printer is telling to me see troubleshooting
This is the Brother definition of error code 4F:
"The head drive voltage has dropped from the high to low level in an abnormally short period." or "The head drive voltage has not risen to the specified level within the specified period in the self-diagnosis"
Causes:
"Piezoelectric ceramic actuator defective (Cracks or rare short)"
or
"Main PCB defective"
No simple fix I'm afraid. You could contact a Brother repair agent but I expect they will want to charge you more than a new machine. Sorry.
SOURCE: see troubleshooting and routine maintenance
Error 46 in my printer brother DCP-165-C any help please
