Question about SanDisk Sansa e250 MP3 Player
When i formated my sansa, it died suddenly! when i connected to computer, driver was not found!what to do? help me immediately!
  • 8,596 Answers
Unplug the Sansa from the computer. Uninstall all Sansa software using Windows' Add/Remove Programs feature. Reload the software, either from the installation CD or Sansa's website. Then, replug the player into the computer. If it still fails to recognize:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 14, 2009
All of a sudden my Sansa player died. I
Have you tried plugging it in your computer? Try plugging it in and reset it. I hope you have luck.
Jul 09, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip sandisk 2gb won't charge. Thought it was low and after plugging it in to computer overnight it wasn't fully charged but worked the next morning but suddenly died. Now it won't charge. Sansa...
I had the same problem this morning, albeit with my 8G Clip. Nothing worked -- the thing seemed dead as roadkill -- until I found a link about "forcing MSC mode." Basically, it told me to hold down the center button while plugging my Clip into my computer using my USB cable. Suddenly, boom! It's awake and alive and happy again. I'm unsure how that works, but that did it for me.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
Computer will not read Sansa Fuze
did you try to connect from your sanza to onboard usb don't use the front of your pc usb maybe wrong setup or wrong connecting the wire . use the usb located at back of your pc , if you connect the sanza to you pc if have words appear ( found hardware)it mean the sanza need the software driver and you unable to detect without driver..
Jul 05, 2009 | SanDisk Sansa Fuze MP3 Player
Suddenly shut down
-Tha Mp3 Doctor
Feb 25, 2009 | SanDisk Sansa Clip MP3 Player
Driver is missing
You can get all drivers/software from Sandisk's website
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
-Tha Mp3 Doctor
Sep 16, 2008 | SanDisk Sansa Clip MP3 Player
Free memory
Format
This will format your Sansa c200 player’s internal memory
1) Select Settings from the Main Menu.
2) Select Format
3) Select Yes to format the internal memory or No to cancel.
-Tha Mp3 Doctor
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Aug 03, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
i tell you connect to the computer your device
and right click on your device and format it
Jun 09, 2008 | SanDisk Sansa Clip MP3 Player
Few issues with my sansa..
Sounds like your music may have become corrupt.
You can follow these steps to erase and start anew.
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Nov 08, 2007 | SanDisk Sansa e250 MP3 Player
Shutting off/ dieing
-Tha Mp3 Doctor
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa e250 MP3 is buggin
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Oct 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
