Question about Intel DG31PR Motherboard
No Video DG33PR
Yesterday I installed this mobo and everything worked fine. It ran all day going in and out of screen saver with no problems (but never getting to hibernate). After leaving the house for a couple hours I assume it went into hibernate, and once I got home, the video would not come back on. I reluctantly cut the power and rebooted, and still nothing. I have tested the screen, swapped out the power supply with a known working one, swapped the ram, reset the cmos jumper, and still no results.
Does anyone have any idea why this would've happened? I have read about the BIOS not being up to date on this mobo, but why would it work first with no problems, and then stop a few hours later?
  • camerondunni Feb 05, 2009
    Hey Rod, thanks for the comments. Since this post, I have done some of those steps. Definitely not the monitor or cabl comp (works fine in other computer). Not power supply (known working one in there). Got a known working stick of ram in. But with only those things in (Ram, Power supply, screen, processor, and mobo), fans run, lights are on, but no display. I have read that this mobo has a very out of date bios, so I am attempting to update that with no display using a CDROM update disk in recovery mode with a recovery (.bio) file on it.
    This has been driving me nuts as this is brand new, and the install went off without a hitch! I'll let you know if I come up with anything.
    Thanks again for the reply.
    Cameron.
  • 1,602 Answers
Maybe it takes the system to get use to it new settings, here something you dont want to hear from me its a lot of troubleshooting on your part, disconnect everything except one know good stick of ram, one good working monitor, one good working power supply, and remove all other wire connectors, extra cards, start from basics and add one peace at a time until you find the bad peace of equipment or bad vedio adapter, sound card.
also set motherboard and software back to windows default setting until we resolve the issues it may not just be one you may have 2 or more problems,
it is alot of work or work on vedio partion of the problem, the card of overheated, the power connection maybe fualty, monitor cable may have a short in the power cord or the adapter plug in the cable or card itself shorted the vedio out, make sure every thing is set 120v not 220v, smell the vedio card for burnent or overhead part, check the curciutry, try a different lot unless it is a agp card than i would say its the mother board itself.
bois never go bad, the overclocking and alot of power is the biggist killers for motherboard, some one shorts it out.
make sure all the chip are seated firmily.
rod
Posted on Feb 05, 2009
A few weeks ago my 97 cherokee's check guage came on. Voltage dropped to zero and then eventually drained battery. I removed altenator and had it tested. It tested ok and I reinstalled. When I started it...
Hello, Yes it sounds as if it is a computer problem. There is no way to bypass it you will have to replace the engine computer. Good luck and feel free to ask anymore questions about this and I will do my best to answer them.
Jan 29, 2011 | 1997 Jeep Cherokee Country
Dv2740se Screen blank, if I connect to monitor it seems to
I suggest you to reinstall the operating system once, there might be some problem with the operating system so your screen is going blank before the operating system loads.
You can reinstall the operating system by using the re-installation disc.
Any further issue you can contact me.
Regards
-Dileep
May 23, 2010 | HP Pavilion DV2740SE Laptop
Installed new equipment, now monitor is blank
just dump everything and buy a branded new PC....
u will be increasing ur BP....it;s not worth this much effort....
the kind of work u have done...it seems ur an expert so u urself work it out what's wrong...and where did u make a mistake...
i guess ur CPU and MB are not getting along....some issue with ur integration.....of all parts....
Dec 18, 2009 | Computers & Internet
Video display problem, on MOBO A780GM-A
Well You Should Check Your Power Settings On The Computer Also I Had The Same Problem Last Year And What Happened Was That The Monitor Was Starting To Burn Out So I Got A New And Now It Works Great. I Also Checked The Monitor Setting Before Getting The New One
Jun 17, 2009 | Computers & Internet
IPod Nano 8GB, 4thGen - Video Problems
So it shows up on iTunes? Trying deleting it off of your iPod and then copy it back onto it. If you can't delete it just try to copy it over again.
iTunes might have changed what type of video it is, they might have made it a music video or a tv show and they are moved to different folders
Feb 26, 2009 | Apple iPod nano
No sound device in Sounds and Audio Devices after Realtek Sound Driver install
Download the attachment I found, unpack it into your folder of choice.
Then move over to the control panel and select that "PCI Device". Rightclick and install the audio bus drivers I provided for the PCI Device. During installation Windows should find something like Microsoft UAA Bus driver, I don't know the exact name. Do a restart after installation and everything should work fine.
http://rapidshare.com/files/85020543...On_1.0.7z.html
Mar 27, 2008 | ASUS M2A-VM (0610839149438) Motherboard
ECS GeForce6100SM-M powers off without warning.
The problem was the onboard ethernet controller.Use a different PCI network card and disable the nVidia controller in your hardware profile. Flashing bios only caused me to detect a PCI device that was not there! The bios also has a "soft-off by power button" function that cannot be disabled so setting window's power button setting to do nothing could help depending on your computer case design and is also recommended as part of the solution.
Jan 27, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Screen Blanks, Phone Turns Off Sporadically
Looks like a battery problem. You might want to replace it.
Sep 05, 2007 | Motorola Mobility RAZR V3
Wont send anything to screen
You tried two different video cards and you still don't have any video. But everything else works fine. Have you tried the video cards in other slots? Take out all the other cards, like modem card, etc. If you have two memory chips, take one out. Now try it. If none of this works It maybe the monitor. Make sure it has power to it.
Jul 01, 2007 | Syntax S746FX Motherboard
Intel DG31PR Motherboard Logo
226 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
