Question about HP Photosmart C6180 All-In-One InkJet Printer
Won't fax -printer message is "will dial soon"
I have a HP4110 all in one printer and have had no problems in faxing. Suddenly I can't fax at all - when I enter number and hit start it immediately puts message up "will dial soon" but it never does. Have tried sending to several numbers, unplugged and replugged everything, rebooted, talked to my carrier since my DSL line is my fax line and DSL is working fine
Would appreciate any help - dead in the water
  • gg4519 Feb 06, 2009
    Thanks for trying but this is same printer and phone line I've used for over two yrs - nothing has changed
    Genius:
  • 2,120 Answers
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Posted on Feb 06, 2009
Why did my fax machine suddenly stop working?
Check that the memory is not full. Also, make sure a setting like (auto-dial 9 for outside line) is set incorrectly.
May 17, 2015 | Office Equipment & Supplies
Faxes sent to queue won't fax
Hi
Please check the your telephone line, take one analog phone and fax cable put in phone and check u get the dial ton on not, if not then your telephone line have a problem contact to your service provider.
If u get the dial ton then, check the fax setting, and cancel the all faxes, then restart the fax machine the check again to send the fax.
May 08, 2011 | Lexmark X364dn All-In-One Laser Printer
Need to know what bod rate is on my fax
older fax machines used a 9600bps baud rate, meaning a transfer rate of 9600 bits per second. a Bit being an 7th/8th of a byte. The newer machines can transfer at 14400bps, which older machines can not read, as its too fast. thats why they asking the BAUD rate.
Aug 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Fax error message = TX cancelled:RX fax info mismatch???? Cannot send fax - How do I fix this error - Not all faxes return this message
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Hope this helps. aknz
Jul 31, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Cannot send fax with a proper working phone line hooked up
I have exactly the same problem! did you find a solution or reason???
Mar 19, 2009 | Brother MFC-9440CN Laser Printer
Having troubles with fax not dialing out
Disable call waiting is only set to "yes" if you have call waiting, press "menu" then scroll down to "reset all setting" make sure to backup phone entries before doing this . Follow the "fax settings" below:
FAX SETTING FOR 5500 (VOICE MAIL)
- ANS. MODE TO "YES"
- ANS. MACHINE RINGS "3"
- FAX RINGS TO ANS. "4"
FAX SETTING FOR 5500 (ANSWERING MACHINE)
- ANS. MACHINE RINGS "4"
- FAX RINGS TO ANS. "3"
Nov 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Answering machine problems with Lexmark X4270
Thats an easy one, if the all in one is attatchd to pc and not stand alone, go into your pc settings, go to printers and faxes under control panel and take the fax off default setting. It will no longer be able to dial the fax and should revert to answereing. also check if your fax mode is set correctly for what you want. It may be on fax mode only so it automatically dials fax. Good luck.
Nov 17, 2008 | Lexmark X4270 All-In-One InkJet Printer
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
Original jam message
A semi-full reset returns the user settings to the factory defaults.
It also deletes the following information:
* Language and country settings on some models
* Fax logs
* Fax headers
* Fax speed dial information
To perform a semi-full reset first unplug the power cord, then press and hold the "#" and 6 buttons on the front panel keypad while plugging in the power cord.
Feb 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
146 people viewed this question
Seeker5211
Seeker5211
