Question about MSI K8N Neo4-F Motherboard
4 red led's
K8N Neo was working fine. Had some glitches with the USB ports no biggie. No the system will not post at all..hard drive runs fine on another machine. 4 Red Led's at the back of the board? I assume this is not a good sign. Any thoughts?
  • 38 Answers
This sounds like a corrupt BIOS, or another issue with the northbridge. It's possible the motherboard was cooked by your power supply, I've had it happen. You will probably be able to use all of your parts in your computer, but you'll more then likely have to replace your motherboard, and maybe processor. The harddrive, video card, and other parts should be fine.
Posted on Feb 05, 2009
Both my desktop and laptop computers do not recognize my Signature mini external hard drive. I've replaced the cable. No difference. The ports work fine because they work with my printer. I have...
External hard drives of this type are mainly composed of a USB-to-SATA interface & a 2.5" SATA hard drive. If any of these components is defective, then you won't be able to access your data.
So, basically we have 2 possibilities:
1. A failing USB-to-SATA interface. You can test this possibility by disassembling the device, taking the hard drive out, & testing the hard drive in your desktop computer using a 2.5" to 3.5" SATA adapter. If the hard drive works fine, then the problem lies within the USB-to-SATA interface.
3. In the previous step, if the hard drive could not be detected by your desktop computer or is not working properly, then it is the failing part.
Jun 11, 2011 | SimpleTech Signature Mini 320GB External...
My seagate 320 gb freeagent go led is blinking and is not detected by my computer when i connect it to the usb port
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
May 31, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Suggest Hard drive for ASUS K8N Motherboard
ASUS K8N Motherboard support: -
2 x Serial ATA cables - 2 x UltraDMA 133/100/66/33
1 x 2-port SATA power cables - 2 x Serial ATA, support RAID 0, RAID 1, RAID 0+1, JBOD
Your mainboard support both "IDE & SATA" interface, so you can use IDE or SATA Hard Drives.
Hope it helps.
Nov 14, 2010 | ASUS Computers & Internet
The hard drive is flashing red and blue. Is it done?
Even though it is possible that your USB hard driveis corrupt, but
before you finally conclude, try out these few troubleshooting
First of all, it is possible that the USB port that you are using is a
USB 1.0 port, which has a lower voltage not enough to
power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a
USB 2.0 one (Just keep Checking all the ports one by one in case
you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in
an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy
a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Meanwhile, before you try out the second option, test the drive on
a friend's system, that you are sure has a very good system, with
USB 2.0 port.
If after trying out all these, the USB Drive still doesn't work, then
I'm afraid, the drive might have been bad/spoilt.
Kindly keep me posted about the problem and let me know how it
Hope this helps you out.
Thank you for using Fixya
Oct 07, 2010 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
My desktop all of a sudden cannot detect the sata hdd. earlier it was working fine. Now it is not detecting the hdd and the red led is also blinking
First make sure there are no loose cabling/glitches.
Does the drive spin up?
- check power cable
1. connect the drive to another port
- port may be broken
2. connect another drive instead
- drive may be broken
Aug 18, 2010 | Computers & Internet
My harddisk do not ditect, i have tried very much.
i suggest make your hard disk to be slave..then you can copy what important file in that hard disk and save it to the other hard disk..
try to connect it to others pc with master hardisk tha runs good..then you will see if your hard disk still works there..if you can't open may have corrupted or bad track disk..or maybe worst.. you hard disk is damaged...
Feb 08, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
SATA Drive on MSI K8T Neo upgrade hard drive. More detail.
Sata drives are backwards compatable so should work no problem but some drives have a jumper that needs to be reset ,check the website for your drive.
Aug 10, 2009 | MSI K8T Neo-FSR Motherboard
K8n neo platinum 7030 v1
hiya i have fixed the computer , but if you want the answer, as i am a msce certified engineer, u can sign up to me , for a price.
Sep 17, 2008 | MSI K8N Neo-FSR Motherboard
MSI K8N Neo4-F Motherboard Logo
156 people viewed this question
Top MSI Computers & Internet Experts
Alun Cox
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
