Question about Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher
Long Run Time and dishes don't dry
Two problems, may be same root cause. During a normal cycle, the "Water heating" light comes on and stays on for quite a while delaying the cycle from progressing. Manual says this will happen if the water is below 120F. Mine is 130F. Possibly a bad temp sensor?
Also dishes don't come out dry. The heater coil is not hot to the touch if I open it during the drying cycle. Is that definitive that I need a new heating element? Is it easy to replace without causing subsequent leaks around the connection points?
Thanks for any help.
  • 1 more comment
  • marty571 Feb 05, 2009
    Not sure I understand your question. I meant that my normal water temperature is 130F (measured at the kitchen faucet), so it did not make sense to me that the "Water Heating" light would come on (and it does at least once during every cycle). The light eventually goes out and the cycle does proceed. I have no way of knowing what the actual water temp inside the tub reaches setpoint or if it just times out a some point and the cycle continues. Again, I suspect a bad temp sensor, but don't know where it is in there.
    I can't feel the back or sides, I just opened the door during the dry cycle and gingerly touched the heating element. It was the same temp as everything else in there (about 120 I would guess, but did not measure).
    Thanks for looking into this for me
  • marty571 Feb 06, 2009
    OK, thanks. The cost of the element seems cheap enough. Any tricks I should know about getting the old one out and the new one in without having leaks afterwards?
  • Garth Jackson May 11, 2010
    Sound to me like the element is just not getting to temp as fast as it should but what i need to know before I tell you to go and spend money is ,does the unit continue washing when the water reaches 130F or does it heat past that?and when the machine goes into dry cycle is there heat at all feeling the side of the machine or the back if you can get there is usually a good indicator.
    Scholar:
  • 93 Answers
I do not think that the temp censor is fualty as if this was the case it would more than likely get so hot that plastics would melt but as you say the element is not hot and the machine does eventually continue this leads me to believe the element is blown or just not heating as it should I would tend to replace it,but what you can do is before you remove the element take the wires off the element and test it with a multi meater to see if you get a reading if not then you know the element is fualty and replace.
Hope this is of some assistance to you and that you do come right,let me know if there are any other changes or problems you encounter and we will see what we can do.
Posted on Feb 06, 2009
  • Garth Jackson Feb 06, 2009
    There is not really any tricks as such just remember unplug the unit before you work on it and when you replace the element make sure the element is in place and sucured tightly and you should be ok
Kenmore Ultra wash mod.# 665-77963K703. normal wash light flashing. How do I reset.
How many times does it blink before pausing and repeating? 7 times? (That's a common problem - means "water not heating" error.) In some dishwashers, instead of pressing Heated Dry, Normal Wash, Heated Dry, Normal wash, you press the 3 left-most keys in the following order: 1, 2, 3, 1, 2, 3, 1, 2, 3. That will start the diagnostic cycle and clear the error, but if you don't find and fix the cause, the problem will come back the next time you run the DW. But before I try to explain how to fix the root cause, I would need to know how many times the light is blinking.
Jan 09, 2015 | Kenmore Dishwashers
How do you turn up the heat on the dish washer drying cycle?
There is no way to turn up the heat of the dishwasher during the drying cycle. As part of the current ecological, energy-saving, environmentalist-wacko movement, dishwasher makers have cut back on the heating used to dry dishes. But you can do these things to help with drying:
1. It is imperative that you use rinse-aid (Jet-Dry). This allows more water to flow off the dishes and what flows off does not need to evaporate.
2. If the dishwasher has the options, turn on high-temperature wash and sani-rinse. This gets the dishes hotter for better evaporation during the dry cycle.
It is possible that the heater may not be working at all, and that will cause poor washing performance and no drying. That problem can be caused by a bad heating element, or by a bad controller.
Sep 21, 2014 | Whirlpool Dishwashers
I have a hotpoint mfg#HDA2100VCC brand new and its leaving this brownish film on the residents dishes. Everything cycles fine and ive checked her water to make sure it isnt hard or carring rust deposits...
those dissolving detergent packs are the cause of 80% of warranty pump failures. i have even seen them wedge under the heating element and catch fire during the drying cycle. it could be from the detergent. but most likely it is from iron deposits in the water that you cant normally see that oxidize during the drying cycle. install a simple filter on the water suppy, change to a liquid detergent, and run the diswasher with some vinegar inside a few times after installing the filter.
Sep 26, 2013 | Hotpoint Hot Point HDA2100VCC Built In...
The "clean light" is flashing
Indicates control hasn't sensed a rise in water temp during heat cycle. Make sure you hear the water being circulated during wash cycle. If so the heater, control board, thermostats or wiring are most likely bad. If heater, therms, and wiring check good its usually the control. When fixed press Heat dry- Normal-heat dry-Normal or High temp- air dry-high temp- air dry to reset control.
Sep 25, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
Model # dwu7702aae has heat delay light coming on during cycle. Why?
Heater is used to both heat water during clean cycle and dry dishes after wash cycle. Most washers have either a separate switch for Heat or Dry for optional use, or some have the water heat and dish dry options built into cycle set options.
You can save money by turning off the Dish Dry option since it is a very in-efficient way to dry dishes. Instead, open the wishwasher door after washing cycle completes, just enough so fresh air can get into, and humid air can escape, dishwasher.
Water Heat option is only needed for dried food on dishes, and is never needed if dishes are either rised off before putting them in the dishwasher, or rinsed off inside the dishwaser with a Rinse cycle, if they are to stand for a time waiting for a full dishwasher for wash.
Feb 22, 2009 | Maytag Dishwashers
Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher Logo
241 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
