Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Ip address after rest is setting at 169.254.58.1 and the land con
The land connection of .255.255.0.0 due to this I can't find the setup IP. If anyone can help out quickly it would be great thank you.
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    IS this a brand new install?
  • Ryan Peterman
    Ryan Peterman May 11, 2010
    is it a router issue or are you talking about your computer?
  • 73 Answers
Your computer is not getting an IP address from the router. My guess is that you're trying to connect to it wirelessly without knowing the wireless security settings.
Try connecting directly to it using a network cable, configure the wireless settings and try again.
Posted on Feb 06, 2009
How to connect my self and make my IP address ?
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
Feb 07, 2015 | D-Link dlinkgo Wireless N 150 Router...
How do i get to the linksys router setup 192.168.1.1
If the IP address was ever changed you may need to rest the router by holding in the Reset button at the back for 30 seconds and then turning off and on again. This should reset all the settings including the IP address to 192.168.1.1
May 01, 2011 | Linksys Wireless-G WRT54G Router
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am unable to connect to the intenet using a wireless connection (signal strenght very good) when I use the repair wizzard I get a message telling me that i am unable to renew my IP address
u dont worry your network connection setting problem you go to network settings and give ip address 192.168.1.1 and another pc 192.168.1.2 to 255 any of one this 2 to 255 ok
enjoy bye
Jan 26, 2010 | Fujitsu Siemens LifeBook N3520 Notebook
What is the ip address for it's network/ethernet card?
The external ip address (the one assigned by your isp) can be found at: http://whatismyip.com/
The internal ip address (differentiates the computers on your network) can be found by running the command prompt (start --> run--> cmd or start--> all programs --> accessories --> command prompt) and then typing int eh following command: "ipconfig" (without quotes). It will be the set of numbers in the form 192.168.something.something
Good luck, let me know if you have any questions
Dec 28, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
My computer is saying connected to router but no internet and my cable light on the router is not lit. (yes the cable is active on my tv) Any suggestions on the problem and a solution
if its the first time you connected the router ...you have to make the wlan connection ..and clone the Mac address on the router to fit the old mac that u had on computer card..
this in case ia have a static ip address and you need to make the internet connection with the provider... after that select from your pc network setting to obtain an ip address automatically ...and you put the sub-net mask at 255 255 255 0 and the default gateway as the ip address of the router ...
do not forget the router is now your connection with the provider so there is where you set the provider 's settings ...
if you have a modem too just select at the wlan in the router .to obtain an auto ip ...and in the computer too ..you may also clone the mac adress cause the provider may have it ..and block the acces cause didnt recognize the new one (router's Mac)
Jul 30, 2009 | Linksys WCG200 Wireless Router
I have Windows XP Pro, SP2, Office 2007, and an HP Photosmart C7280 off a wireless router. Printer scans OK but 9 times out of ten it can't see the PC. DHCP is "on" but printer IP address is sometimes Auto...
The problem is you want to have the printer on a fixed IP address. This can be done by reserving the IP for the mac address of the printer in the router OR simpler just set the IP address in the printer.
Change IP settings
The default setting for the IP settings is Automatic, which sets the IP settings
automatically. However, if you are an advanced user, you might want to manually change
the IP address, subnet mask, or the default gateway. To see the IP address and subnet
mask of the HP All-in-One, print a network configuration page from the HP All-in-One.
NOTE: When manually entering an IP Setting, you must already be connected to an
active Network, otherwise the setting will not stay when you exit from the menu.
CAUTION: Be careful when manually assigning an IP address. If you enter an invalid
IP address during the installation, your network components will not be able to connect
with the HP All-in-One.
To change IP settings
1. Press Setup.
2. Press until Network is highlighted, then press OK.
The Network menu appears.
3. Press until Advanced Setup is highlighted, and then press OK.
4. Press until IP Settings is highlighted, and then press OK.
If the HP All-in-One is already connected to a wired network, you are prompted to
confirm that you want to change the IP settings. Press OK.
5. Press until Manual is highlighted, and then press OK.
6. Press to highlight one of the following IP settings, and then press OK.
• IP Address
• Subnet Mask
• Default Gateway
7. Enter your changes, and then press OK to confirm the setting.
Jul 04, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
When running the setup CD, I get a Site Survey failed. Anyone have any ideas?
I can help you configure your expander manually instead of using the CD.
You can connect your expander to your PC via ethernet cable and then assign a static IP address on your PC.
To assign a static IP address, just double-click on the monitor icon on the lower right hand corner of your PC and then view status and go to properties. Look for TCP/IP v4 and click properties.
Select use the following IP address:
192.168.1.2
255.255.255.0
and then click OK.
After successfully assigning an IP address to your PC, let's test the connectivity by going to command prompt.
Go to Start>Run>and then type cmd and hit Enter.
Once you're on the black screen type ping 192.168.1.240.
If you get replies then your good to go...
Let's now access the Web UI of the you Wireless expander.
Open a browser and then type on the address bar 192.168.1.240 and then hit enter.
It will prompt you with WRE54G's username and password. Just type the password to login to the Web UI. The default password is admin.
Once your on the Setup page, you have to configure your settings exactly the same as your wireless router (e.g. wireless security, IP address range) except for the SSID. You may want to change the SSID on your WRE54G for you to easily identify where your wireless computer is connected.
You can leave the WRE54G's IP address to 192.168.1.240 if your wireless router's IP address is on the same range like 192.168.1.x
Then on the Gateway address type your router's IP address. If you're also using Linksys the default IP address usually is 192.168.1.1
Then you can configure your wireless settings same as your router. After that, same the settings and see if the light on the WRE54G becomes BLUE. If yes, then you're good to go! You can unplug the PC from the WRE54G and then set your PC's IP address back to Obtain an IP Address Automatically. See static IP address procedure above.
Jun 09, 2009 | Linksys Wireless-G Range Expander (WRE54G)
Setup
If that is the report that the laptop gives for an IP address, then you have to change the IP address settings.
Go into your network settings, and tell it to automatically aquire an address, and DNS.
Once you click OK, it should sense the DCHP from the router.
If the IP is already set to automatically aquire, then the router needs to be reset to factory defaults. That should put you back to the 192.168.2.xxx settings.
Jul 27, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
126 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
