Question about HP Officejet 5610 All-In-One InkJet Printer
Cant print off compute
Can copy a document on the officejet and can scan to my computer from the officejet but I cant print out something from my computer on the officejet; after I hit the print button on the computer to print, nothing happens
    Scholar:
  • 24 Answers
Hi Grubeman,
The issue seems to be with the printer drivers. To confirm whether the issue is with the printer drivers or with the application, try to print from all the other applications and check for the result.
I have two solutions for your issue.
1. Set "print directly to the printer" option
2. Alternate drivers.
To set the Print directly to the printer option, do the following steps.
1. Open the printer folder
2. Right click on the printer icon and select properties.
3. Click on the Advance tab and select "print directly to the printer" option.
4. Click apply and ok.
5. Nothing else, just try printing dear!!
The second solution, I will post, once I found that the above steps does not resolve your query...
BYE.....
Posted on Feb 07, 2009
When making copies, only a part of the document prints; the rest is solid black.
Solid black in a copy typically means that the scanner is partially blocked. Open the top, where you'd place a sheet to be copied, and examine the small strip that runs down the side (left, most likely). See if it's clear, or if something is covering part of it.
Most copiers don't use the full size scanning plate for copies, but use a strip that scans the paper as it moves across it. If something blocks part of it, you get the black area.
Apr 12, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
Vertical lines when copying from feeder or glass - does not happen when printing from computer or scanning documents.
Inspect the glass below the feeder for ink or ink correction liquid remnants from previous scanned documents. Clean them out.
Oct 08, 2014 | HP OfficeJet Pro K8600 Printer
My officejet pro 8500A prints black vertical lines down the page when I make a copy. I have cleaned and aligned the printheads. What else can I do?
Happened with me too. Turned out to be a small sticky smudge on the ADF glass. That is the smaller glass scan area to the left of the large glass scanning area.
When using the ADF to scan or copy, make sure the smaller glass area is clean along with the rollers.
Oct 05, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My HP6110xi All-In-One doesn't want to scan
First, scans and copies don't really use the computer. Can you print a document from your printer. If not, then your problem is within the computer.
If it does print then....
Try using the scan feature within the HP solution center. It works on mine but the scan button on the printer does. Also some art programs have and "ACQUIRE" feature under file to scan with. (Sometimes called TWAIN.)
Hope this helps, so you can start scanning.
good luck
Feb 21, 2010 | HP OfficeJet 6110xi All-In-One Thermal...
It will not scan, prints, copy, but not scan
hi... have some idea about your problem... maybe u should try this... try to install your twain driver of your printer first then next is the scanner driver... then you'll fing what will happen next... thank you very much...
Jul 21, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Hp officejet 4255 all-in-one
Once try to scan from the computer to check whether there is a communication between the computer and the all-in-one. If you are not able to scan then reinstall the all-in-one software. If you are able to scan then refresh the spooler and enable the print directly to printer also delete any pending documents and then try to print.
If you are still not able to print then install the alternate drivers by performing the steps given in the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=npu00132&cc=in&dlc=en&lc=en&jumpid=reg_R1002_INEN
Jun 03, 2008 | HP OfficeJet 4255 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
