Question about Ferrari Acer 5000 PC Notebook
Upgrade to 4GB, network shows unplugged!
When I bought my laptop acer ferrari 5000 with 2GB memory, I didn't experience any problem. but when I upgrade it to 4GB the lan network always shows unplugged and I cannot connect it to anything, I tried so many ways to solve this but the only way was to remove one of the rams (so it will have 2GB again) then everything goes fine. I think it has something to do with the bios. but my laptop has the latest bios update!
I'm not sure what to do.
  • 1 more comment
  • flexaxe Feb 06, 2009
    thank you for your response, and I also think this laptop is great too.
    I bought two kingston pc2-5300 (KAC-MEMF/2G), accourding to kingston website, they made this for the ferrari 5000, and I bought it because of that.
    I used cpu-z to check, and also kingston website, but I couldn't find whether it is SoDimm or dual channel.
  • flexaxe Feb 07, 2009
    I just finished testing the sticks one by one and they both fine, any idea what to do?
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Are you sure that your computer can even hold 4GB of memory? The reason that I ask is because it says that the 5000 can hold 4GB but only run 3.
    President:
  • 1,073 Answers
Thats a NICE pice of laptop you got there M8!:)
Yepp, it supports 4GB ram, i have a Ferrari myself:) and i have 4GB ram in it whit no problems at all.
Are you sure you bough the right memory-stick for your acer?
It requires two SoDimm DDR2 667mgz dual channel supported sticks. Make sure that u using those ones, otherway it wont work.
Let me know how it goes for you
Nic
Posted on Feb 05, 2009
  • Nicolas
    Nicolas Feb 06, 2009
  • Capacity: 2GB x 1
  • Target Use: Notebook
  • Type: DDR2 667 (PC2-5300) So-Dimm (200-Pin)
  • Thats the spec i found about those sticks, they seems to be good for the ferrari.
    Maybe one of the sticks isent OK, try to run the free program Memtest, you can download it from here
    http://www.memtest.org/
    That will at least give you the answer if both stick ar OK, test them one by one if possible. The program is easy to run, just follow the instructions how to use it. It takes about 30-45 minutes to test eatch stick.
    Good luck to you M8!
    Nic
Get black screen after upgrade Acer 3680
might be that the ram you got was the wrong ram for that laptop.not all ram work in all laptops.
May 23, 2014 | Acer Aspire 3680 Laptop
AOD270-1824 can i put a 4gb ram in it
You can add 1GB of ram but that's it. Definately not a 2GB Stick or 4GB stick.
Sep 01, 2012 | Acer Espresso Black 10.1" AOD270-1824...
How to install ram memory
General two options:
1. Look at bottom of laptop and notice the memory icon. You will need to unscrew the panel to upgrade memory.
2. Memory is under keyboard in which you will have to remove keyboard to upgrade memory.
May 09, 2012 | HP Acer Aspire As7750g-6645 I5-2450m 1gb...
I just purchased a new Acer Aspire AS7741G-6426 Laptop. I want to upgrade from 4GB memory to 8GB memory. I need to know what brand and specs to look for.
Just refer to your laptop manual. If your manual got lost go to the  acer website and find your product and download the manual.http://www.acer.com.ph/ac/en/PH/content/home .
when upgrading your memory you have to consider the following:
the processor: if your processor has 4gb compatibility mem you can upgrade upto 6 to 8gb.
                      take note that you must not exceed to 8gb or else your processor might be damage.
                      get the processor speed: example core 2 i3 processor, 1.0GHZ-the frequency.
the Memory or RAM(random access memory): get ther specification: example is DDR1 or DDR3
        PC133 or PC 400. Thats all.
Note: your current memory must have the same memory module(example PC400,PC 133)  or else it wont work.if your going to upgrade your current 4gb PC400 you have to add 4gb memory in PC400 module also.
May 01, 2011 | Computers & Internet
What is the maximum memory I can install
Memory Upgrade for Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop, the Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop takes the Memory Type, and comes installed with 0MB of Memory. You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory, already with 0MB standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jul 08, 2010 | Acer Aspire 5630 Notebook
Acer Aspire 5601 4GB memory upgrade problem
Acer systems are picky about the type of memory you use.
What is your RAM Speed on the old chips compaired to the new chip
You may have to reorder the same type of speed memory
Try this website it will tell you what will work with your system
http://www.ec.kingston.com/ecom/configurator_new/mfrmod.asp?root=us&LinkBack=http://www.kingston.com
Aug 22, 2009 | Acer Computers & Internet
Upgrading memory to 4GB failure
try to see if that memory is supported with your motherboard. The memory has something to do with that problem.
Jun 16, 2009 | Acer Extensa 5620 Notebook PC
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Ferrari Acer 5000  PC Notebook Logo
124 people viewed this question
Top Ferrari Computers & Internet Experts
David Payne
David Payne
Are you a Ferrari Computer and Internet Expert? Answer questions, earn points and help others
