Question about Krups 287 SensoToast Deluxe 4-Slice Toaster
Krups toaster won't work.
I have a Krups Electronic toaster with push buttons for thawing and reheating, both of which seem to work fine. But, the actual toasting function seems to have broken down, not sure why.
This is a long, white body toaster made of plastic, can hold 4 slices, 2 on each side. There's a dial with 6 settings next to the other two push buttons. Specs are 120V, 60Hz, 800W. Two other numbers listed are 29086 & 885258.
I've had it for a long time with no problems till now. Not sure where to go from here, can't see the model listed anywhere online, so, maybe they stopped making it.
Any ideas anyone? Thanks in advance!
-SR
    Genius:
  • 1,689 Answers
I do not know the exact inner workings of this toaster, but I can suggest what the fault may be.
Many of the toasters use a separate high power section in the eating element for toasting. This part of the element could have gone defective. There is the possibility the computer board that directs the power for the higher temperature mode for toasting has failed.
The only reliable way to know is to try the computer board, element assembly, or the switches if the switches are on a separate module than the computer board.
Just to add... These toaster units usually have a thermo protection fuse. These fuses have a temperature rating. It would be in series with the element. This fuse may have failed. This is a common fault in many of these types of units. This type of fuse is rated in Degrees C or F, and not in Amps. it is a thermo fuse.
Posted on Apr 02, 2017
2 Suggested Answers
SOURCE: krups toast supreme 4-slice toaster stopped working
The element has burnt out, IF you can get another it is worth repairing, IF NOT, then it is time for a new one.
Posted on Apr 13, 2010
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Why are the control buttons operate intermittently?
Sounds like there is a loose wire connection. Have you contacted the manufacturer?
Aug 11, 2014 | Krups FBC212 1600 Watts Toaster Oven with...
The toast button does not work properly anymore, guessing there is something wrong with the contact?
My toast button did that for a while then got better. Also, try holding the button in for a few seconds instead of a fast hit.
Jan 27, 2012 | Krups FBC2 1600 Watts Toaster Oven with...
My Krups Sensotoast Deluxe just stopped working. Can you help me? I really don't want to throw it out because it's relatively new and I expected a product with this name to last a lot longer.
The printed circuit board is likely burned out. It's pretty sad really. This is a poorly designed toaster. Krups owes us new toasters in my opinion. Looks like a fire hazard too. If you are curious, you can remove the 4 philips head screws out of the bottom of the toaster, gently pry off the push down lever and the dial, and examine the board and connections. 8_25_2012_1_16_19_pm.jpg
Mar 27, 2011 | Krups 287 SensoToast Deluxe 4-Slice...
Setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Krups toast supreme 4-slice toaster stopped working
Apr 13, 2010 | Krups FEA212-45 Toast Supreme IV 4-Slice...
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 30, 2009 | Krups Toaster Ovens
Krups Toaster Oven elements stopped heating up
this is all to common . what thought happend did happen . the control board went bad and the elements where stuck on . inside there is a thermal fuse ,it blew out and saved you from haveing a fire but now the oven is dead . if you replaced the fuse it would just do it again and the board cannot be bought so your out of luck . on your next oven stay away from electronic controls . i am shocked you got 3 years out if it ,most go bad mutch sooner
Feb 26, 2009 | Krups FBC1 1600 Watts Toaster Oven with...
Machine won't work
This machine does not have that muck electronic, the button switch has probably a short, and must be replaced.
As said the machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Jan 03, 2009 | Nespresso Aeroccino Automatic Milk Frother
How can I turn off the annoying "beep" on my Krups Toaster Oven?
Check out this link; might or might not help you:
http://applianceguru.com/forum1/15129.html
Please post whether this works for you.
Good luck, Sam
Dec 20, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
Krups 287 SensoToast Deluxe 4-Slice Toaster Logo
266 people viewed this question
Top Krups Kitchen Appliances - Others Experts
Mike
ArcFlash
Level 1 Expert
Oloyede Monsuru
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
