Question about Ruud UBHC Air Conditioner
Ruud achiever 90 plus won`t start at times
System is on calling for heat but furnace won`t come on.When it does eventually come on it cuts out before the programmed thermostat temps. When this happens 1 of the 2 green furnace lights blinks once repeatedly.This seems to occur when it is really cold outside. At other times the furnace works fine.
Any suggestions.
    New Friend:
  • 92 Answers
Sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Posted on Feb 05, 2009
How to clean clogged condensate drain of ruud furnace achiever 90 plus
You can easily blow through the drain with pressurized air through the p trap. There could be a number of reasons the furnace side is not working. In the case of windy conditions there is a possibility that your pilot will need to be adjusted or the flame sensing rod might need to be cleaned. If the pilot wavers off of the sensing rod it could cut off the heating cycle because the system could not verify a flame yo bring on the main gas valve to continue with the cycle
Mar 01, 2015 | Ruud Heating & Cooling
Ruud achiever 90 plus furnace will not start with door on.
I would try to check your return air first, making sure there is no blockage and that your air filters are clean. It almost sounds like when you take the cover off, you are pulling enough air into the system for it to run, but as soon as you close it off, it's not getting enough air flow, therefore, tripping a limit switch inside the furnace. Most furnaces will also have the codes for the flashing lights and what they mean on the inside of the door covers.
Feb 02, 2010 | LG LW1200ER Air Conditioner
Ruud Achiever 90 plus not blowing air
the motor is bad or start capicitor
Aug 29, 2009 | Heating & Cooling
Check the data information on the unit there should be a troubleshooting guide that tells you what the two lights blinking once means. hope this helps.good luck. normally found with schematic
Feb 05, 2009 | Ruud UBHC Air Conditioner
RUUD Furnace not coming on
the fuse that your refering to is on the control board indie of the furnace. shjould be a 3 amp. good luck.
Jan 30, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Ruud Achiever 90 Plus wont start
4 blinks is "pressure switch closed" there are 2 in the system according to the wiring diagram one for the vent system  and one for the drain system ... I just wiggled them and heard one "click" the fault light quit blinking and when I pushed the safety switch back in the furnace fired right up.  That being said is there a good website for learning how to maintain your own furnace?  I'll call a pro if I have to, but shoot I can fix a jet engine... this shouldn't be much worse.
Thanks  dan
Jan 19, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
813 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
