Question about Epson DFX-9000 Matrix Printer
Print heads for dfx 9000
I have a problem with frequent replacement of print heads for dfx 9000.
Every month 1 print head.
Print line - 1300000(Dec) every month.
  • 37 Answers
If you replace the printhead and dont change the alpha an beta value, your printheat was damage shortly
Posted on Aug 22, 2009
Need a print head for Epson DFX 9000
Spare parts you have to order via Epson, but I'm not sure they still have print heads for matrix printers.
I found a site in China, but perhaps you even can find more on Google? dfx 9000 print head
Jul 27, 2014 | Epson DFX-9000 Matrix Printer
OD ERROR
Fatal error code 0D: No head error
A check of the print head thermistor circuit during power-on initialization determined that the PRINT HEAD is not installed. This error is caused by the following:
? The Print Head is not installed.
? The Print Head built-in thermistor element has failed.
? The Carrier Cable is disconnected or damaged.
? The Print Head temperature detection circuit has failed
Jun 07, 2011 | Epson DFX-9000 Matrix Printer
Error 16 turn printer off
Hi -
The error codes 16 means that you need to check the print head thermistor circuit during power-on. Printer initialization determined that the print head itself is not installed. Some cause of this is again the print head is not installed, the print head built-in thermistor element has failed, carrier cable is disconnected or is already damage, print head temperature detection circuit has failed.
Having said this, it is better to have the printer check by a qualified technician or your local service provider
Hope this helps,
Good Luck!
Feb 28, 2011 | Epson DFX-9000 Matrix Printer
DFX 9000, just over 1 yr old, Skipping lines withing the print. Then generate error OD
From our FixYa forumn:
The error codes OD means that a check of the print head thermistor circuit during power-on initialization determined that the print head itself is not installed. Some cause of this is again the print head is not installed, the print head built-in thermistor element has failed, carrier cable is disconnected or is already damage, print head temperature detection circuit has failed.
Having said this, it is better to have the printer check by a qualified technician.
http://www.fixya.com/support/t1051554-epson_dfx_9000_error_code_od_ob
Feb 01, 2011 | Epson DFX-9000 Matrix Printer
Opened my printer espson dfx 9000 and im getting an error 16 how do i overcome this?
OPENED MY PRINTER EPSON DFX-9000 AM GETTING AN ERROR 16 HOW DO I OVERCOME THIS
Jul 23, 2010 | Epson DFX-9000 Matrix Printer
DFX-9000 printing 2 Journals on 1 page instead of 1 per page
Have you tried to check the print settings?
Click on Start>Control Panel>Printers(Printers and faxes)> Right Click on the DFX-9000 printer icon>left click on properties>click the printing preferences button located below the properties box. In this window you should see the setting of the printer itself.
Sep 05, 2009 | Epson DFX-9000 Dot Matrix Printer
Epson dfx-9000 printer is showing error 0D when it is switched on
check print head built in thermistor and the carrier cable.
Nov 20, 2008 | Epson DFX-9000 Matrix Printer
EPSON DFX-9000 ERROR CODE = OD and OB
error code OB turn off the printer, why?
Sep 17, 2008 | Epson DFX-9000 Matrix Printer
Request
This error OE is linked with the Print Head Driver.
2 solution:
1- Check the print head cables (continuity, shortcircuit, connection etc..
2- Print head Driver on the Main Board is out of order > Change the Main Board.
Mar 17, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Matrix Printer Logo
477 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
