Question about Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens
Canon xTi won't power up
After 18 months of great photography my Canon xTi, it died on me. Now I read that I'm not the only disappointed Canon customer. Hopefully, the repair bill won't be too much.
Pat in Toronto
  • 2 more comments
  • Anonymous Feb 24, 2009
    hey i got the same thing im about to send it in can you tell me how much you paid. thanks
  • Anonymous Mar 14, 2009
    same here. Would not power on today, took it to a camera store and they are sending it out for an estimate. A body cost around 350 on ebay.
  • womies May 04, 2009
    I tried replacing the watch type battery inside but that did not help. I called a camera store and they said repair would run $175-$250. The camera is less than two years old.
  • John LeFebvre May 11, 2010
    So what is your question please?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 155 Answers
I think the problem is that these cameras are very sensitive to the battery being taken in and out - if you leave the camera swtiched on, and remove and re-insert the battery, it can cause a very small fuse in the camera to blow. Always ensure the camera is switched to "off" before doing anything with a battery...
You can fix it yourself if you are happy disassembling a very delicate piece of hardware!
Posted on May 18, 2009
New Canon EFS 18-135mm IS lens failed to auto focus on EOS Rebel XTI and shutter won't release to take photo. Lens over a few months has worked without a problem. What is the problem?
Make sure both the lens and the camera are switched to af (auto focus). If that doesn't work remove the lens and replace it to make sure it is mounted properly. You can also check the camera with a different lens to make sure it isn't a problem with the settings on the camera. If all of that fails take it to a camera or electronics store that does service work to make sure it hasn't been damaged.
Jul 30, 2011 | Canon Cameras
My Canon xti stopped working at my son's graduation. I had a full battery and took a few photos.....then turned it off.....and when I turned it back on again, it was completely dead. Tried several...
Hiyou might have a problem of either main pcb or power control pcd (dc/dc convertor). it is common but it cost. It cause usually come from loosen screw going around inside and short. If it is lucky, then your unit would just a fuse brown. If not, it has to change main pcb and all of computer adjustment is involved. Your local repair shop would charge you around $65 to 235.
Jun 04, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon xti and canon 420ex flash giving
Make sure the 420EX is set to E-TTL and set the camera to "P". If is need of more light, increase flash exposure to +1 or 1.5.
Oct 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Whats the best economical lens to use for indoor photograph with
If you are new to photography in general and especially SLR photography I would suggest holding off on buying any lenses besides the 18-55mm.
The reason I suggest not buying extra lenses just yet is coz you need to get to know your camera and if you are new to SLR photography then you need to get your fundamentals right. Sure the 400D will let you shoot in full auto mode but you will really not learn much doing that and certainly not be making the most of your camera in that process and that will extend to your new lenses too.
Get used the the control, the 18-55 is a great little cheap lens with the pop up flash it will work great for most family pics. The 55-200mm is a new "cheap" lens, its been marketed as letting you go beyond 55mm thats why it starts at 55mm goes to 200mm.
Hope this helps you...
Jan 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Cannot transfer images from my Canon DSLR XTi to my computer
Having same issue as above - I thought it was my cable so I ordered a new one. The camera attempts to 'speak' to the pc - and then the Windows box pops up not recognising the USB installed device....I also uninstalled and reloaded the Canon software (had camera for 18 months and only started this rubbish a month back) - was about to re-laod my entire PC - thankfully I saw it was not only me.
Will send mine in for a Firmware update / service.
Mar 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon EFS Lens question- please help!!
Make sure that the switch on the lens is set to AF. If that doesn't work, you may have a faulty lens. The EFS 18-55 is not a high quality lens.
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Indoor photography
If you're on a budget, the 50mm f/1.8 II is a great deal, $100ish, f/1.8 is great for low light.
If you have a bit more cash, the 50mm f/1.4 has better build quality (the 1.8 is all plastic) and much better autofocusing (its USM so its fast and quiet, as well as more reliable) and its also slightly sharper.
If you want a zoom, from canon theres the 17-55 f/2.8, which has image stabilizer and USM focusing.
Also, the 24-70mm f/2.8L, which has USM, and since its an L lens, fantastic optical quality. However, it will run you over a thousand most likely.
From sigma, theres several zoom options, the 28-70mm F2.8 EX DG, 24-70mm F2.8 EX DG MACRO, and 24-60mm F2.8 EX DG. All under $800 or so.
Dec 03, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Xti wont power up
appears to be a defect and not user serviceable.
sorry for the news.
good luck.
mark.
Nov 25, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Will not autofocus
same issue here, but with 18-200mm. worked for 18 months fine.
Nov 03, 2007 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Logo
430 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
