Question about Mitsubishi VS-60607 TV
My VS-60607 won't turn on
Hit the power button and it clicks for one second and turn off.
dear mark i have the same problem to when i turn the tv on it will stay for 2 second and turn off do you have a solution for this please give me some help thanks.
    Problem Solver:
  • 7 Answers
There is a fuse blown in the television keeping it from staying on. after the shutdown press and hold the menu and device/input button for about 5 seconds and the led will blink a 2 digit code with a pause in between. the code will repeat itself. 2.2 is the most common and points to the convergence ics and 1 or 2 5a pico fuses. 2.3 is the next most common and points to a fault on the power supply. goodluck.
Posted on Feb 05, 2009
VS-60607 turns on then off
2,1 is X-ray protection or excessive High voltage
It is a circuit repair or may be related to a Glycol leak
Mar 13, 2012 | Mitsubishi VS-60607 TV
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
Jun 07, 2008 | Mitsubishi VS-60607 TV
Mitisubishi 60607 will come on the go right back off
you have a component failure. begin checking the on-board fuses. that should lead you to the circuit that failed. most often it is the convergence circuit. 2nd most is a loss of vertical deflection. this is a tube protection circuit that shuts the set off before it destroys the crt's.
Jan 06, 2010 | Mitsubishi VS-60607 TV
Power interruption model vs 60607
These units have had issues with the Yoke plug connections on the Yokes being intermitent. I would advise only a professional to check it out.
Hope this helps,
Jul 04, 2009 | Mitsubishi VS-60607 TV
Mitsubishi vs 60607 circuit board
this isn't a notorious problem. many problems can cause this. the instant on/off behavior just says there is one of many fuses blown in the television. you can't just replace the fuse, when it fails get a failure code find out what it means and repair the problem. I would recommend paying someone to do it if you don't want to trash your mits set.
to get the code you hold down the menu and input button for 5 seconds after the on/off sequence. it is a 2 digit code with a pause inbetween, example 2 pause 2 pause 2 pause etc. is a 2.2 code
Jan 23, 2009 | Mitsubishi VS-60607 TV
unit will power on for a second then shut off. power supply ?
Oct 27, 2008 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 60inch projection TV, cannot turn on
i have the same and i am having issues with the screen going dark when its suppposed to be a white screen and the picture is darker than it should be during normal watching of tv. also there is a line at the top(letterbox style) of about 1- 1 1/2 inches......anyone know how to fix this
Feb 22, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Won't turn on right
check your smps in your tv or Ic is collapsed
Feb 17, 2008 | Mitsubishi VS-60607 TV
Tv powers on, then switches off immediately
check out and find error codes
Oct 07, 2007 | Mitsubishi VS-60607 TV
Need help
If you have no TV repair experience, or any experience tracing circuit flow with a schematic, call in a tech to assist you with this repair. This tv set is not the place to be experiementing inside of. You probably have bad capacitors in the power supply or the sweep power supply. Good Luck
Sep 30, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
383 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
