Question about eMachines T6534 PC Desktop
T6534 WANT BOOT UP. SYSTEM RUNS INSIDE.POWER SUP?
OK, I PUT MY NEW HARD DRIVE IN MY OLD COMP.AND HOOKED UP BOTH AND GOT IT TO WORK AND RECOVERD THE HD.I PUT IT BACK IN MY T6534 AND THEN I CHECKED THE POWER SUPPLY CONNECTORS. GOT LIKE .2VS AND THE LARGE ONE WAS 1.5VS. IT MIGHT BE THE POWER SUP.BUT WHY DO THE FANS RUN AND HD?I CHECKED THE CPU IT LOOKED OK . WHATS WIERED IS THAT I CAN UN PLUG MY CD/DVD AND THE TRAY WILL OPEN AND RUN THE CD AND WHEN I PLUG IT BACK IN THE MOTHER BOARD NOTHING HAPPENS THE TRAY WANT OPEN. IT JUST WANT BOOT UP. NOTHING ON THE MONITOR.
    President:
  • 1,902 Answers
You power ratings are ok on the main power supply. But you should check the volts on the internal and see what is happening.
Posted on Feb 05, 2009
My Dell PC scan says that my Samsung SP2504C hard drive is about to fail and should be replaced. Is this something I can do?
Replacing the hard drive involves the following process:
  1. Turn off and unplug the computer
  2. Remove the two screws from the left panel (facing the front of the tower)
  3. Slide the left panel back and to the left to remove it
  4. Unplug both power and data from the hard drive
  5. Unscrew the hard drive (You may need also remove the right panel to get to additional screws)
  6. Slide hard drive out
  7. Slide in new hard drive.
  8. Screw in new hard drive in approximately the same fashion as previous hard drive was screwed in
  9. Plug in power and data
  10. Re-install panel
  11. Plug computer in and boot
However, if this is your main or only hard drive, you will need to install your Operating system and all of your software and files from scratch. It may be possible to preserve them, but that's often risky and requires a bit more work. If this is your main hard drive, you probably want to consult an expert on having the old drive contents moved to the new drive.
If you like my solution, please vote for me,
Apr 09, 2011 | Samsung SpinPoint P120 SP2504C 250 GB SATA...
Tip
How to fix a bad hard drive.
If you have a hard drive that crashed and can't live with the thought of starting over .. there is one last thing you can do to get your info from the disk!!
FREEZE IT... YES.. i said to put your comp. hard drive in the freezer...
First you need a ESD bag (antistatic bag) You are going to need a new hard drive anyways. When you get your new hard drive. it will come with a ESD bag over it..
Put the old hard drive in the bag...
Put the new drive in your comp.
Put the hard drive in the freezer over night..
24hours in the freezer = about 30mins run time... might get more time out of it if you freeze it longer but ... you will just have to test it
put the hard drive in and test it... if it works ( like it should ) you can use the old hard drive as a backup and keep freezing it to get the info off.
on Mar 28, 2010 | Computers & Internet
My old emachine was turned off the wrong way and will not boot.What can I do?
File corruption can happen when power is cut from the computer. Put a Windows cd into the drive and load up the recovery console, then run CHKDSK. If you don't have a windows cd, take the hard drive out of the emachine and connect it to a working comp. Then you can run chkdsk.exe from inside windows to fix corrupted sectors.
If your computer is powering on, that is an entirely different question. Be specific.
Feb 07, 2010 | Computers & Internet
No boot device available - strike F1 to retry boot, F2 for setup utility after getting the blue screen of death
Your PC is telling you that it cannot recognize your Hard Drive. You need to order a new Hard Drive. They are very cheap. Then you will need to re-install Windows. All of your data may be lost, but you can bring your Hard Drive to a data recovery center or PC Store to see if the data can be retrieved.
Hard Drive is probably dead so you will need to purchase a new one.
Sorry and Good Luck.
Oct 15, 2009 | Dell Dimension 8400 PC Desktop
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
How do i transfer data from windows 98 formatted drives 2 xp ones
Set up your old drive as a slave and copy the data. Good luck.
Jun 19, 2009 | Computers & Internet
How do i format my hard drive on my old compaq 686 465mhz machine running xp sp2.Cant seem to get it to recognize f11, or other keys to get it to system prompt outside of windows.
This link will take you to Dell there you can make a boot disk you might have to change boot order to floppy drive first. This disk will give you the option to format fat32 or NTSF. Run fdisk to check the how your disk is partitioned.
http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=boot+disk&cat=sup
Mar 09, 2009 | Computers & Internet
EMACHINE T6534 COMP. WANT BOOT . TRYING TO CHANGE V-CARDS
This could be a few things though if you have already checked the memory and HD. The next thing I would tell you is that you should check the cpu. Also make sure that everything in the BIOS is set to the default settings when you start it.
Feb 04, 2009 | eMachines T6534 PC Desktop
HP 750 desktop pc won't boot up...?
Thank you for contacting Fixya. If its loading operating system then there is no problem with hard drive. Its absolutely a software problem. Please reinstall a fresh copy of Operating system i.e., Windows Xp / Vista whatever. and install the proper drivers for the system. Hopefully it should work. Again if same problem occur then you need to check the RAM. I mean is the system re-boots again and again hten clean the RAM slots or insert the RAM in other RAM slot. There may be some dust inside the slot. Try these steps. Hopefully it should work. Thank you......
Sep 14, 2008 | Computers & Internet
System won't boot
Better you try with a bootable CD, if that works then check for your Hard Disk it might got faulty or crashed.
Feb 04, 2008 | Dell Dimension 4600 PC Desktop
eMachines T6534 PC Desktop Logo
123 people viewed this question
Top eMachines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
