Question about Samsung SGH-L700 Cell Phone
Signal loose the signal,somthime no signal...
    Problem Solver:
  • 14 Answers
Some phones are better than others with reception of signal due to the design of the "antenna" in the phone. Also some cell phone companies have really great service while others lack because they may have less towers.
For example there are 4 phones on my family plan, we all have different phones and some of them dont do so hot on reception, as mine is great, i can even talk on the cell in the elevator.
I know that for some phones there may be 1 or two things you can try. Your best bet is to call your provider and let them know your having problems, they may have a suggestion for the combination of their signal and your phone on what you can try.
More often than not your stuck with what youve got, I know this is not what you want to hear but check with your provider..
Posted on Feb 05, 2009
Completely loose tv hd signal for days then signal comes back
Sounds like you have a loose cable ( either inside or outside ) that allows moisture in. Or you might have a tree limb or other obstruction.
Mar 15, 2013 | One For All OUTDOOR HD ANTENNA RCA ANTENNA
My Jaguar Stype Diesel 2.7 V6 somthimes at low speed when it is the automatic position is sort dragging. If I increase the accelarator it is OK. Also rarely when the engine is cold and I start it a huge...
I would say that your friend could be in the right area
diesel injectors operate in the worst possible conditions and are prone to dirt and other problems
ahe the injectors reconditioned and set by an accredited diesel specialist shop
May 25, 2017 | 2007 Jaguar S-Type 2.7D
I have a lawnmower that is hard to start, and once it gets going it will run for 5 or so minutes and then bog down and cut off. It needs to rest for about 10 minutes and then can be started once again for...
sounds like its flooding itself out
Carb problems can be a bear, I would check the flote at the bottom of the carb it may need to be cleaned possibbly oiled and somthimes the even get a hole in them
Jul 29, 2011 | Garden
Intermittent turn signal problem 2005 malibu
Check that the fuse for the turn signal is not loose. Sometime a firm push inside is needed. If that doesn't work replace the fuse. If it is still loose then take a narrow pice of wire and insert it in with the fuse to keep if from being loose.
The problem could also be at your turn signal stalk. Turn of the turn signal and then move the turn signal stalk in different directions and hold it. You are trying to see where the intermittent problem goes away. If it doesn't , then the stalk is fine.
Aug 17, 2010 | 2005 Chevrolet Malibu
Acer monitor(AC502) screen display just went off leaving very little line showing "shut off computer" after one of my collegue pressed one of the menu button from the monitor.Tried pressing the main menu...
IT NEEDS SERVICING NEAR VERTICAL IC AREA...RESOLDERING THE MAIN BOARD AND HEATED PARTS. IN SOME CASES LIKE YOU HAD MENTIONED, THE CAPACITORS AND RESISTORS SOMTHIMES ARE ALSO A PROBLEM..SO IF YOU ARE ABLE TO DO IT URSELF TEN TRY OR MIGHT YOU WILL NEED A QUALIFIED PERSON FOR THE
Oct 15, 2009 | Computers & Internet
My Sansa Clip won't turn off once charged.
my screen will turn off in on and when ever i have it hooked up to the comp it works but once off nothing not anything at all it iratates me i just want to kill it somthimes
Sep 25, 2009 | SanDisk Sansa Clip MP3 Player
LG 26 inch lcd. Recently it loses the signal from sky remote eye
hi! maybe there is a problem on power supply section or loose connection.
Sep 01, 2009 | LG 26LG30 26 in. LCD TV
Replaced ignition cylinderw/key but the key dosnt come out
sounds like the cable is not latched in properly
Jun 21, 2009 | 1997 Pontiac Grand Prix
GE Spacemaker dryer scraping metalic sound when on
i know you say ge dryer but i think thats a frigadire inside ge dosent make an over under.When dryer off take your hand and go around the in side of the tub where it meets the felt seal.some times somthimes somthing will get caught between the turning drum and the felt seal causing a noise.if not that you have some wear problems and will have to take apart to inspect
Dec 31, 2008 | GE Spacemaker Washer and Dryer Electric...
NAD 7155 Receiver's tuner not working.
I Have a Captive Works which suddenly loose signal when a file is loaded.
I factory reset it and Quality and level returns but as soon as i reload a bin file i loose signal.
Can you help with a solution?
Harpic
Mar 08, 2008 | Audio Players & Recorders
Samsung SGH-L700 Cell Phone Logo
126 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
