Question about Logitech Harmony 880 LCD Remote Control
Everything OK =NO IR Output=IR Indicator display indication OK
Control worked fine for 2 years. Stopped while making a selection, All indications on the control are good. Camera test shows no IR output. Ir indicator indicates it is transmitting. Tried downloading settings but no help, all indications remained the same.
See this link for instructions on replacing the IR LEDs:
Link
Posted on Sep 08, 2009
I have a 2002 GMC Envoy, Quite frequently my charging light will come on and state that I only have 10 volts coming out and then all the sudden jump to 14 and work perfectly fine
How many mile are on you vehicle ? Have you ever had Alternator replaced before ? You alternator maybe starting to fail , brushes or the voltage regulator .
Charging System Indicators
BATTERY The IPC illuminates the battery indicator when the following occurs:
The PCM detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the PCM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the body control module (BCM) indicating the system voltage.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
The ignition is on, with the engine off.
BATTERY NOT CHARGING The IPC illuminates the battery not charging indicator in the driver information center when the following occurs:
It would be a good idea to have it checked out , most auto parts stores will do this for free !
Dec 29, 2015 | GMC Cars & Trucks
Zodiac ei series salt levels are fine cannot increase chlorine indicator light above 20%
need more info is this connected to a system if so you have to change it in the system if not on a system sounds like a bad control board
May 19, 2014 | Zodiac Nature 2 Cra30 Replacement...
How to program a 4.0 IR/UHF PRO remote
The general setup proceedings to a universal remote control is as follows:
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the dropdown list by the 'Sidebar' of the display window. It will make search easy.
Mar 12, 2013 | Televison & Video
Tv remote wont work the lights turns on but still wont work
There are two ends to IR control; the remote itself and a receiver inside the set that is active any time the set has AC available. Testing the receiver end requires a known-working remote control but you can check to see if the remote is still sending IR signals by taking any digital camera you have on hand, turning it on as if you wanted to take a snap of something, watch the display while you aim the working end of the remote toward the camera's lens and holding down any button on the remote. If the remote is sending IR signals, you will see these as white spots, often blinking rapidly, on your camera's LCD screen.
If the remote is outputting IR, the receiver in the TV is likely dead and will require replacement.
Jun 01, 2012 | RCA Televison & Video
My tv wont work with the remote i can turn on by hand but remote wont do anything it has new batterys and the red light goes on
TV brand?
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
LG:
1) Test the remote:
2) If the remote checked out OK, then look at the back of the TV for the "REMOTE INPUT", use a mini-phone plug and insert the plug into the remote input jack in and out a couple times to clean the switch contacts that select between the front IR receiver of the TV or the rear panel IR input jacks.
Oct 30, 2011 | Televison & Video
Remote just stopped working the TV, but it still works the directv cable box
See step 2:
LG:
1) Test the remote:
See: http://www.fixya.com/support/t9056223-remote_doesn_39_t_work_all
Oct 07, 2011 | LG 37LC7D 37 in. LCD HDTV
Non functioning batteries ok just stopped no liquid involved not dropped
www.remotes.com
LG:
1) Test the remote:
Aug 23, 2011 | Televison & Video
Remote won't work. Tried new batteries, reprogramming, etc. Universal Remote doesn't work either. LG #42PC5DC
To confirmed if the remote control is working fine, aim the remote control sensor(IR emitter) directly to your cellphone camera. While pressing any button key on the remote control, you can see the flash of an infrared emitted by the remote control if it is working fine.
If you've confirmed that the remote control emitted an infrared but still the tv won't communicate with it, this is an indication of faulty IR sensor board of the TV. Check if there's an obstruction from the IR receiver in front. Keep away all of it, clean the plastic window of the IR receiver with soft clean cloth.
If the symptoms still persist, you have to replace the IR sensor board. Check the actual part no. of the board before ordering.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 22, 2011 | LG Televison & Video
I have tried everything . My Motorola Hs850 will not connect. It keeps indicating that the connection failed
Firstly, make sure you have enabled Bluetooth on your phone or whatever device your using the headset with. The default setting off, so go into your phones set menu and enabled Bluetooth.
You'll then need to 'pair' the headset and phone.
1. Ensure the headset is turned off (indicator light not blinking).
2. Press and hold the Call E button for 4 or 5 seconds. The indicator light will initially flash, but continue to hold down the button until the indicator light is steadily lit.
If the indicator light is flashing or not steadily lit when releasing the button, repeat both steps 1 and 2. Hold the Call E button for 4 or 5 seconds.
3. Enable Bluetooth on your phone and get to 'search for devices' it should find the headset.
4. Select Motorola HS850
Select OK or Yes to pair your headset with your phone. Enter the passkey: 0000 Select OK. When your headset successfully pairs with your phone, the indicator light changes from steadily lit to flashing.
Hope this helps. Oh and make sure your phone actually supports the headset!
Jun 13, 2011 | Motorola Mobility HS850 Consumer Headset
Logitech Harmony 880 LCD Remote Control Logo
276 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
