Question about Ruud UBHC Air Conditioner
Ruud achiever 90 plus won`t start
System is on calling for heat.Furnace will not come on when temps falls below thermostat temps and if it eventually does comes on it cuts out below thermostat programmed temps. When this happens one of the two green furnace lights blinks once repeatedly.This seems to happen when it is really cold outside. At other times the furnace works fine.
Any suggestions.
  • 56 Answers
Check the data information on the unit there should be a troubleshooting guide that tells you what the two lights blinking once means. hope this helps.good luck. normally found with schematic
Posted on Feb 12, 2009
I am installing an Emerson programmable thermostat. We have a Ruud furnace achiever 90 plus that was installed 14 years ago. The thermostat mentions a power stealing switch.
The Ruud furnace is probably compatible. Power stealing is a way to recharge the thermostat battery from the 24vac control voltage used to operate the furnace. If you install the Thermostat in the "separate power supply mode" it does not need to power steal ever and will be much more reliable. Some thermostats don't get enough power in the power steal mode to keep the battery reliably recharged, especially during the cold winter months because the poiwer available to "power steal" is highest when the furnace is NOT running. You will need a separate 24 vac transformer and some wire.
Jan 06, 2018 | Ruud Heating & Cooling
Ruud achiever 90 plus furnace will not start with door on.
I would try to check your return air first, making sure there is no blockage and that your air filters are clean. It almost sounds like when you take the cover off, you are pulling enough air into the system for it to run, but as soon as you close it off, it's not getting enough air flow, therefore, tripping a limit switch inside the furnace. Most furnaces will also have the codes for the flashing lights and what they mean on the inside of the door covers.
Feb 02, 2010 | LG LW1200ER Air Conditioner
My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Ruud Achiever 90 plus not blowing air
the motor is bad or start capicitor
Aug 29, 2009 | Heating & Cooling
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
RUUD Furnace not coming on
the fuse that your refering to is on the control board indie of the furnace. shjould be a 3 amp. good luck.
Jan 30, 2009 | Ruud UBHC Air Conditioner
Where is the re-ignite switch on a RUUD achiever 90 plus furnace?
Te flame symbol on the T-stat is just telling you that the T-stat is calling for heat.
What you need to do is go to the furnace and see if there is a blinking light. If there is count the blinks and look for a blink code list on the wiring diagram.(Usually found on the main panel.)
After you have done that, disconnect power to the unit, and then reconnect after a few minutes. This will reset any auto switches if they are tripped.
Chances are the problem will occur again even if the furnace does fire back up, but it "may" get you through the night until you can either diagnose the problem or get a service tech in.
Ideally, have someone else turn the power back on, and the thermostat, while you are watching the furnace to see exactly what is happening.
If it does not operate properly at that time, let me know exactly what it is/is not doing and we can go from there.
Dec 29, 2008 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Ruud UBHC Air Conditioner Logo
908 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
