Question about Kenmore Refrigerators
Whirlpool side by side refrigerator not cooling
I ahve a 10-year old Whirlpool Eterna ESS22XGMCC side by side refrigerator where the freezer compartment is getting plenty cold but I am not getting cooling in the refrigerator side. Vacuumed off the back Of the unit but didn't help. Adjusted temperature settings but didn;t help either. I ahve not pulled th back voer as of yet to check for icing of the evaporator coil but I won;t hink that it is fine as the freezer section has been holding temperature jsut fine. Any suggestions?
  • 700 Answers
Yes do the check for the baffle. set the controoler for the thermostat to off and the freezer to the coldest setting while have the doors open. take the cover off the baffle and observe if its closed . should close in 10 seconds, also the compressor should be on, as should the evaporator fan and the condenser fan. turn the controls the oposite and the baffle should open. Also make sure that you have seperation of product so that you haev adequate air flow in frig.
Posted on Feb 07, 2009
Our whirlpool side by side frig has water in the bottom of the freezer side, is only a year old. What is wrong?????????????
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Jul 02, 2011 | Whirlpool Refrigerators
We have a side-by-side about 4 years old, freezer is working fine but the box is not cooling. What should we check?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Nov 25, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Freezer stopped cooling, less than 1 year old
Due to being less than 1 year old , you need to call a Whirlpool factory authorized service center for repairs . This repair will need to be done under warranty . You could try unplugging for a few minutes and then plug back in to reset the electronics .
Jun 13, 2010 | Whirlpool GC3NHAXVY Stainless Steel Side...
GE Eterna stopped cooling. Not even 2 years old!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. The noise if you listen close is probably the klixon cycling because the compressor is hot. If the condenser is plugged (real dirty), sign of a clean house, and/or the condenser fan is bad you will not get cooling. If the condenser fans operating properly and the fans inside the freezer and refrigerator are operating that would indicate serious problems assuming the compressor is operating.
Good Luck,
Dec 01, 2009 | GE Refrigerators
Frigidaire not cooling & freezing cold enough
We ahve a two year old Frrigidaire Freezer. every year same time it seems to correct itself(?), like self defrosting etc, and takes a long time come back to its cooling level. This is made in brazil G series. Please help.
V/r Syed
Dec 23, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer / Refrigerator not cooling
When the fans are running the compressor should also be running. If the compressor is hot but not running you have a compressor problem. If the compressor is running check for frost on back wall of the freezer compartment which would indicate a defrost system problem. At five years old have you cleaned the condenser where the heat is transferred to the outside air in the room?
Nov 19, 2008 | Whirlpool ED5FHEXMQ Side by Side...
GE side by side not cooling properly/outside surface hot
please check the condenser fan motor. it is probably not running or the condenser is very dirty.
remove the rear cover and it will show you the compressor and the condenser fan.
if the fan is not running, try to rotate it manually and feel if it is sticking .
if it is, it may just need the old wd 40 lubricant.
tnx 4 using fixya,
Sep 07, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
271 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
