Question about HP Compaq nx6310 Notebook
Usb drive i cant get display of removable disk in computer but at tool bar it says that a new usb hardware is installed and i also set the option display components enable
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    When you open up my computer do you see the drive in there?
    Scholar:
  • 152 Answers
If you go into Device Manager (through Control Panel), see if there are any yellow ! next to the usb controllers. If so, you will need to reinstall the drivers for the USB. Those drivers will be on your HP disk. If you don't have a disk, the drivers are universal and will be installed by Windows. If that doesn't work, try uninstalling ALL USB controllers and hosts and reboot your machine. Once it boots back up, you will be prompted with the Found New Hardware wizard which will want to install the USB controllers and hosts. That SHOULD solve your problem.
Please remember to rate my solutions! Thanks
Posted on Feb 05, 2009
My 8Gb Tevion USB drive shows No Media
Try this , it has worked freat on my drives
Super Stick Recovery Tool V1.0.2.19.rar
http://www.mediafire.com/?81t60ysdvquymsq
Jun 30, 2010 | Electronics - Others
I CANT FORMAT MY MEMORY CARD....I DONT KNOW HOW TO FIX IT.
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
ok
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
A problem in pen drive!
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Feb 04, 2010 | Electronics - Others
USB External Hard Drive cannot access. Disk
If the drive is available, with a blue bar in disk management, just right click on it and select 'change drive letter and paths'. This will allow you to assign your own drive letter.
If you have more than one external drive or if you use daemon tools, powerISO, they may be trying to occupy the same drive letter, which would explain your problem...
If you see a black bar, it would seem your partition was corrupted and you would need to try and recover your data, if necessary (recuva recovery software is an option) and then repartition the drive.
Hope this helps!
Jan 23, 2010 | Western Digital Computers & Internet
My computer says found new hardware but when it tryies to install it says there was a problem does a search and finds nothing. So i cant update the firm ware,i already formated the zen but it did nothing...
When you experience next making connection:
Connecting the device to the computer Wizard found new hardware pops up.
Only this time the Windows update searching for software will not work on automatic routine:
ending up with "Cannot Install this Hardware".
Solution:
Manual performing the wizard, setting the device to USB connection type:
1. Can Windows connect to Windows Update to search for software ?
Select "No, not this time".
[Next]
2. If your hardware came with an installation CD, or floppy disk, insert it now.
Select "Install from a list or specific location(Advanced)."
[Next]
3. Please use your search and installations options.
Select "Don't search I will choose the driver to install."
[Next]
4. Select the device driver you want to install for this hardware.
Select "USB Mass Storage Device."
[Finish]
Note: when using MSC mode always safely remove hardware, the players' removable disk. The icon in the right corner of the task bar.
Once the device can be reached in MSC mode it should be ready to install new firmware on the player:
1. Backup data on the player to the computer when not on the PC already.
2. Reinstall / update firmware from computer to the player: after this the device will have all the maps for writing data and it can be approached in MTP mode again, using application software like Windows Media Player 11.
Need more help, just post a comment.
Oct 07, 2009 | Creative Labs Creative Technology Zen MP3...
I put the usb port in the computer and it will say the computer has found new hardware and for me to install it when i do it will say hardware can't install. what do i do?
Selecting or switching automatically MTP < > MSC
Connecting the player before a media software program is installed, the player will connect as a flash drive also called removable disk in MSC mode.
There are 2 settings for connection mode in the player, MTP and MSC.
See page 36 of the manual for more information and how to set the USB mode:
http://www.cobyusa.com/files/manuals/MP705_MN.pdf
USB mode MTP
Install Windows Media Player 11 for MTP connection to the computer.
When needing a media player update from Microsoft see:
http://www.microsoft.com/windows/windowsmedia/default.mspx
USB mode MSC
Solution:
[Next]
[Next]
[Next]
[Finish]
Oct 01, 2009 | Coby MP-705 Digital Media Player
Boot failure Asus P5Q-EM
Disk boot failure. Issue:Disk boot failure.
Cause: This issue could be caused by any of the below possibilities.
  1. Boot options are not set properly in CMOS
  2. Non bootable disc or USB in computer
  3. Remove added hardware /check connections
  4. Hard disk drive is bad
Solution:Boot options are not set properly in CMOS
Verify that the boot options within CMOS are set properly. Below is an example of how we recommend the boot options be set. Additional information about how to enter CMOS can be found on document CH00192.
  1. Floppy drive
  2. CD-ROM drive
  3. Hard Drive
  4. Other / Network
Non-bootable floppy diskette or disc or USB in computer
Verify that there is no floppy diskette or disc in the computer. If the boot options are set improperly the computer could be trying to boot from the disc drive instead of the hard drive.
In addition to verifying there is no disc in the computer make sure that no USB jump drive, external hard disk drive, or memory stick is inside any memory card reader.
If you're wanting to boot from a floppy diskette, CD, DVD, or USB drive and are getting this error message and have verified that your CMOS settings are in the proper order as explained in the above paragraph the diskette or disc you're using is either bad or does not have the proper files on it to make it bootable.
  • Additional information about how to make a boot disk can be found on our boot disk help page.
  • See document CH000669 for information about creating a bootable disc.
Remove added hardware / check connections
If you've recently installed any new hardware it's suggested that it be removed to verify it's not causing this issue. If after the device has been removed the computer works and it was another IDE / EIDE device ensure that the jumpers are properly set on the hard disk drive.
In addition to removing any new hardware it's also suggested if you've recently moved the computer or installed anything inside the computer that the connections for the drive be checked. Usually it's best to simply disconnect the cables from the back of the drive and reconnect them to make sure they're connected properly. While inside also disconnect and reconnect the cable connected to the motherboard as well. While inside your computer make sure you're aware of ESD.
Bad hard disk drive
If you have followed the above steps and you continue to experience the same issue, unfortunately it is likely that the hard disk drive is bad or the controller is bad.
If available, you may want to connect another known good hard disk drive to the computer to determine if it can be detected. If it is able to be detected then replace your hard disk drive. If it is not detected, unfortunately you will need to replace the motherboard or controller as it is bad.
If no additional hard disk drive is available it is recommended that the hard disk drive be replaced first or that the computer be serviced / repaired.
Jul 01, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
Disk drive does not recognize or read a disk
you could try removing the drivers from your device manager by going through contol panel or by right-clicking on My Computer and then on the hardware tab. you would find it under cd/dvd rom drives.Just right click and click on uninstall. Then if you dont have your driver disk you might be able to download it from softpedia.com. If you have installed drivers more than once you might be able to roll-back drivers but the best bet would be to just uninstall and re-install the drivers.
Hope this helps
Anarkist
May 04, 2009 | LG GSA-E40L Burner
Folder options
ur computer is attacked by virus i can suggest u is install an antivirus updated version and it will remove the virus after that folder options and ur removable disk drives will be displayed
Nov 21, 2007 | Microsoft Windows XP Professional With...
Sanyo VPC-s500 i cant get it to install drivers or find them so i can upload pictures to my computer
The simple solution to this problem is that no drivers are required. This camera is treated as a removable (secondary) drive just as if it was a USB thumb drive or external hard drive.
First go to settings on the camera by rotating the dial to the wrench icon.
Turn the camera on and select Set-Up 2
Select USB
Select PC
Your camera is now ready to use with your computer.
Now plug your camera into your computer and check under My Computer for the drive to show. You can now copy files over to your computer from the camera.
If the drive isn't showing you'll have to go into Disk Management to view it
Disk Management is under Administrartive Tools located in your Control Panel (or Start Menu if you have it set to show there)
Select Administrative Tools
Computer Management
On the left hand side click Disk Management (or on the right click Storage then Disk Management)
Finally you can now Right Click the cameras drive and chose Open
Sep 20, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
HP Compaq nx6310 Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
