Question about Coleman Powermate Powermate 5000W Generator
New gen no power out!
I have a fairly new (1 year, medium to light use) Powermate 5000. It runs fine but no power output. I spoke with a repair man who does service work for Coleman and he suggested that he has replaced the AVR board on many units but can no longer get them due to Colemans demise. what can I substitute for the original AVR board? What component gets fryed, I could replace that piece and keep going?
Sincerely
Don't want to buy a new gen!
    Problem Solver:
  • 3 Answers
I had a very similar problem with my Powermate generator. The repair was fairly simple. I purchased a new capacitor from http://www.jackssmallengines.com/do_it_home.html. The part was less than $10.00 plus shipping. I just put the part number in from the owner's manual. to replace the part you remove the power end of the generator (four long bolts 7/16), Unplug the wiring harness and then remove the three screws which hold the clear plastic shield in place. All you have to do is pull the wires off of the blue capacitor and put the new one in. When you pull the end off you should also look at the diods to see if they look burned. If they do you can get these from Jack's as well. I hope this fixes your problem
Good luck!!
Posted on Feb 07, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Have older powermate 5000 contractor gen. runs great but only puts out 5.5 to6.1 volts. has new brushes
Hello. Plug something into your generator's receptacle, say a trouble light. Then check the output. With no load at all [nothing plugged in, you will get a voltage reading that is low. regards, Joe
Jan 28, 2010 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
Oct 07, 2009 | Coleman Powermate Premium Plus 6250W...
I have a Coleman Powermate 5000 / No power output
Two suggestions. One: check for voltage from the secondary coil wires (if it has one). Two: unless stated do not do this, I have always flashed the excitor circuit through the 120vac receptical. Give these a shoot and I hope it works for you.
Mar 30, 2009 | Coleman Powermate Powermate 5000W...
Coleman 5000 generater-no AC output
have you conected the brushes on the right way? the leads are + and -.
you can run it up and use a 12v battery and connect it to the brushes correct polarity, with the othe LEADS removed and taped can shock you and chect the out put it it around 100 120v chech the AVR or brush polarity.
If yours dont have brushes it will have a capasitor that is prob out of spec.
Jan 10, 2009 | Coleman Powermate Powermate 5000W...
Try replacing the capacitor. You can buy it from http://www.jackssmallengines.com/do_it_home.html. When you pull off the power end of the generator look at the diodes also. If they look toasted replace them as well
Jan 09, 2009 | Coleman Powermate Powermate 5000W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
652 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
