Question about Canon iRC3100 Printer
Canon IR C4080i
How do I know when to change the drum? The drum life looks to be zero but it is still working. Will it stop working completely when it is time to replace the drum?
    Problem Solver:
  • 15 Answers
The drum will either produce an error code of E000020 with multiple subcodes. This is time to change it. Also if your getting weak density or solid backgrounding of a particular color. These are all ques to change the drum.
Posted on Jun 25, 2009
  • mrfixit3441 Jun 26, 2009
    The machine will throw and error E000020-01,02,03,04b0 error.
    01=yellow drum
    02=magenta drum
    03=cyan drum
    04=black drum.
    You may also experience weak density or solid backgrounding of a certain color. This will que a drum replacement.
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
Hello possible to obtain the device reset canon 2202
canon ir 2202 - The Copier Network
www.thecopiernetwork.com > ... > Canon - Black and White
Jul 31, 2014 - 2 posts - ‎2 authors
am facing E0001-000 on new canon ir 2202 ; can any one know how to reset error from this model?
Canon imageRUNNER 2202 - Canon Europe
www.canon-europe.com > For Business > imageRUNNER 2202
The imageRUNNER 2202 is a basic solution to your A3 black and white ... Requestinformation ... Canon's toner and long life drum technology allow users to run theirdevices for longer without the need to often replace consumables. .... We use cookies to provide you with the best possible experience on our website.
Canon iR 2002 2002N 2202N - YouTube
? 1:36
https://www.youtube.com/watch?v=I5ywBlOfwPA
Sep 28, 2014 - Uploaded by Shageesh A
Canon iR 2002 A3 Print, Copy, Scan Canon iR 2002N A3 Print, Copy, Scan, ... How to reset ID and PASSWORD ...
Dec 21, 2015 | Canon Office Equipment & Supplies
My canon ir 2420 is producing black lines
Generally Black line comes when Drum life is over, check your machine counter, one drum life is 35000-50000 print.
Feb 25, 2015 | Canon Office Equipment & Supplies
SIR,i AM RUNNING IR 400 FOR 2 YEARS THIS TIME ONLY wHEN I CHANGE A DRUM THE PRINT WILL BE GOOD WHEN 200 COPIES CONTINUOUSLY TAKING THE DRUM DAMAGED IT MEANS SMALL CRACK ON THE DRUM AT THE FRONT DOOR SIDE...
first, did you install complete Canon original drum unit or just replaced with not genuine low quality drum?
Maybe the problem is in bad quality of drum.
In original drum unit you get whole unit with new drum, blade and charge roller.
Second, you should inspect the developing cylinder, he is magnetic and in some cases something like paper clip or other metal dirt can stuck on it and cause breakage or damage of drum surface.
I recomend you to remove the toner unit, vacume it and check for foreign materials, also rotate the developing cylinder and look for damages or foreign materials.
Hope that something of this will help!
Aug 24, 2011 | Canon imageRUNNER 400S Copier
When printing the printer ( Canon iR C2880) leaves a line devoid of colour running down the pages. how do I solve this or at least do you know what the cause of the problem is?
The problem is probably the drum unit.Try to take out the drum unit and look at the drum.Normaly the color of the drum should be all the same across the drum,but if there is brown lines around the drum thats mean it is tiem to change the drum unit.
Oct 20, 2010 | Canon imageRUNNER iR C2880 Color Copier
Hi! I must change the OPC drum from IR 2230. I dont know how to do this. Thank you!
do you have original drum cartridge or only drum, blade and charge roller?
For complete unit exchange, you can contact me on emma.servis@gmail.com, for service manual.
Best regards!
Sep 02, 2010 | Canon IMAGERUNNER 2230 Copier
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
What is the drum life on a Canon IR c5185? I have a blue drum over 410%?
The drum life of an printer indicates that how much life is available for the printer before you need to change the drup in simple like it is like how much oil is there in your car to make it run smooth once the drum drains out you need to change it
You can get refurbished drum from market at a lower rate as of not it is 410% so you need not have to worry
All the best
Regards
Nov 30, 2009 | Audio Players & Recorders
Canon Imagerunner C4080i
As long as it is a proper ground and a 15amp service it should be fine. On all color copiers I would reccomend that you install a line conditioner (it is a surge supressor plus it filters line noise).
a line conditioner will add a longer life to the copier.
Jan 04, 2008 | Canon imageRUNNER C3200 Color Printer
Canon iRC3100 Printer Logo
305 people viewed this question
old marine
old marine
